Hyde00
Crap I have a Denon D5200, and was on the fence for a while. Should I not buy it?same experience of my friend with denon
Though I'll run it off my PC which might supply more power so it might be ok......???
That happens with W2 too.It seems my drop-out problems are definitely an issue with full-sized headphones and higher volume settings. At 70 in high gain with the Stealth, I get drop-outs if I use my iPhone. Dropping it down below 60 and the cut-outs stop, as does using my iPad or a DAP instead. Of course, this isn't a problem with IEMs.
With my iPhone I never had drop out but ya the connector was getting warm may be due the power it was fetching from deviceI'd say you need different headphones. Trying to fix something you don't like about a pair of headphones with the amp and DAC is just not a good plan IMO.
One thing that annoys me about the EU directive to get Apple to replace the Lightning connector with USB-C is that the latter is simply such a weak connector in comparison. The USB-C connector on my 2016 MacBook is in poor condition, yet I have an iPhone 5 here that has an absolutely solid Lightning socket.
They wont, because customers will swap in dodgy, cheap batteries from China, and then complain to the phone manufacturer when things stop working well. Not to mention warranty claims which people make. It's easier and way more cost-effective to restrict it.
Back to the RU6 though, it didn't want to play well with my iPhone 12 Pro Max, cutting out repeatedly. The W2 didn't fare much better though. I'm using the included Lightning to USB-C cable. I wonder if it is because the battery is below 50%, as it worked fine before, and it works fine out of my iPad Mini.
But it has been fun comparing it with the W2, albeit from a Hiby R6 2020. I've been managing to drive the DCA Stealth from both. I prefer the slightly more bloomy sound from the RU6 for preference, even if the W2 sounds a bit more precise, it's a touch less engaging for me.
Finally I found someone using VC out of this. I really enjoyed the pairing. But I thought I might be the only one.That's weird.
Last night I connected the RU6 to my iPhoneXS, and listened to music for about 2 hours, even in high gain mode since I had my VC connected.
No problems, the only thing I noticed was the Lightning connector gets very warm, almost hot.
All in all, I'm so excited about the little RU6 that I'm now thinking about buying the Cayin 6ii.
Care to explain? The voltage remains the same whether you split or not so I assume it's the same for combining. You can make a light bulb work if you use power from 2 sockets while combining plus + and both - as well, so I'm really curious why it wouldn't work with a DAC. And seeing how many people have problems with drops on higher loads and volumes it's not like power isn't a problem.Now I can understand why you are the last person on Earth when soemone ask you to explain what you believes will work under the laws of physics.
While you can merge two water pipes into one bigger pipe, kind of similar to receive 2 "water supplies" and combine them into 1. This is totally different when you want to apply "summation" concept to electrical energy.
It may be the power related. I remember someone complained of same problem earlier in thread of dropouts at high volume out of iPhone.It seems my drop-out problems are definitely an issue with full-sized headphones and higher volume settings. At 70 in high gain with the Stealth, I get drop-outs if I use my iPhone. Dropping it down below 60 and the cut-outs stop, as does using my iPad or a DAP instead. Of course, this isn't a problem with IEMs.
i think is denon 9200. and the problem is with iphone. i don´t know with androidCrap I have a Denon D5200, and was on the fence for a while. Should I not buy it?
In my experience it's probably a problem on the Apple side. "problem" may not be the right word though if you ask them, lol.
Ah ok then it's an iPhone problem, got it!Apple restricts power draw to 100ma hence the drop outs.
Lol Denon D5200 is pretty easy to drive though. It's like 24 Ohm and high sensitivity (forgot exact number).But now seriously. IMHO dongle is a dongle with inherent limitations due to type of product. If you want a complete hardware that drives large headphones so go to dap. Better batteries, more power!!!
Not sure what you are talking about... I don't have any problem with my Windows 10 laptop or Android phone regarding dropouts. I would like to know how many non-Apple users are experiencing problems as reported in this thread.Care to explain? The voltage remains the same whether you split or not so I assume it's the same for combining. You can make a light bulb work if you use power from 2 sockets while combining plus + and both - as well, so I'm really curious why it wouldn't work with a DAC. And seeing how many people have problems with drops on higher loads and volumes it's not like power isn't a problem.
drftr
The underlying question is what happens if the RU6 receives power from both the socket and the smartphone. Are they both accepted? Is one blocked? Does the thing explode?How is light bulb and DAC/amplifier circuits related in terms of how they can be powered ?
