I got it running at whatever sample rate when i run Qobuz on the iphone 13 pro... It adjusts. Hope this helps.How do I do this? I have the iPhone 12 Pro Max?
Cayin RU6: R-2R USB Dongle DAC with Head-Amp
- Thread starter Andykong
dumpsterfire
iOS automatically outputs the highest sample rate that the active DAC allows (24/48 for the built in DAC or Apple Dongle IIRC) for hi-res content. If the content is 16/44 it will output 16/44. The audio midi setup is only an issue on MacOS.How do I do this? I have the iPhone 12 Pro Max?
If short click and long clicked are predefined, what should I do if I need to change the Gain of RU6?Yeah I see.
I hope in future firmware (if have) a changing: press Menu button (short click) will change the Dac mode (OS/NOS) not regarding screen was on or off.
And long press that button will wake screen up if it was off.
Do you think it is more convinience?
Tnx
It is not as fast as mine, delivery within 48 hours
I like it at very moment unboxing.
I tried insert RU6 into audio path between sources (smp, ak1000) and hdv800/hd800s combo it sounds good. No claim.
(AutoEq of NeutronMp was used on the sources for each headphones)
Stay updated on Cayin at their sponsor profile on Head-Fi.
captblaze
getting my first RU6 listen (ikko OH10) and am finding that the while the image is wide, at times there is a hole in the middle. Imaging in front stage not as present as L/R. Not all tracks, but when i hear it, it is obvious.
That aside, the dongle seems well built and plays nice with my PC and iPhone 13 mini (cable of choice - OEaudio usb c to lightning).
Now to figure out which to pair with KSE1200. RU6 or W2.
emilsoft
- Dec 5, 2014
I think the menu navigation is very functional as is now
How are you finding the treble?getting my first RU6 listen (ikko OH10) and am finding that the while the image is wide, at times there is a hole in the middle. Imaging in front stage not as present as L/R. Not all tracks, but when i hear it, it is obvious.
captblaze
listening with the OH10's the treble is present, but not sibilant. When i break out the KSE1200 I will get a better idea of what the RU6 is doing. For now just some casual listening and rolling some IEMs that I think will pair well with the RU6
emilsoft
- Dec 5, 2014
Do you find it more present vs other sources?listening with the OH10's the treble is present, but not sibilant. When i break out the KSE1200 I will get a better idea of what the RU6 is doing. For now just some casual listening and rolling some IEMs that I think will pair well with the RU6
I still have a CV5. Sadly they are no longer made. I did use it briefly with the RU6 with good results.True, though honestly I had this amp myself and within this price range, I'd recommend the Alo CV5 or better still the Fostex HP-V1. Any tube like element stemming from the BA300s is *really* minimal.
If there's a hole in the middle, that's usually because something is out of phase, either the track or the wiring on something. If it isn't always present, it could just be some of the tracks.getting my first RU6 listen (ikko OH10) and am finding that the while the image is wide, at times there is a hole in the middle. Imaging in front stage not as present as L/R. Not all tracks, but when i hear it, it is obvious.
About the slight etch in the treble, it seems to have gone after leaving it playing music for a couple of days. Using NOS to the SE out to the Campfire Solaris with Spiral Dot tips it has a big, bloomy sound while is wonderful to listen to music with.
captblaze
I don’t have enough listening time with various sources. Just PC and iPhone and neither more than 2 hours a piece.Do you find it more present vs other sources?
And as a disclaimer I have old ears that have been exposed to lots of high decibel noise and am not qualified to give detailed sound impressions
Yup, wish I kept my CV5. Cute amp. Wish I kept the HP-V1, too. Even though it's been clearly surpassed by the Cayin C9, it had a likeable vibe to it. Plus it could be used in desktop mode, too.I still have a CV5. Sadly they are no longer made. I did use it briefly with the RU6 with good results.
TYATYA
Let me try to define Menu button, S=short, L=long:If short click and long clicked are predefined, what should I do if I need to change the Gain of RU6?
1. Scr off: S-> change sampling mode.
L-> wake screen up.
2. Scr on: S-> change sampling mode.
L-> goes to Menu.
3. In Menu:
S-> jump to next item.
L-> scr off
I do hope it in future.
Fast toggle sampling mode is big joy
L-> wake screen up.
L-> goes to Menu.
3. In Menu:
L-> scr off
To be honest, if we are going to keep a menu option, I prefer the simple Menu system as-is. UI is suppose to be simple and intuitive, especially with appliance type device like RU6.
Deders
- Apr 4, 2016
L-> wake screen up.
L-> goes to Menu.
3. In Menu:
L-> scr off
It would be great for switching back and forth when songs and styles change on random, without having to get the whole thing out of your pocket, risk losing connection etc
Deders
- Apr 4, 2016
DP
emilsoft
- Dec 5, 2014
The only think I wouldn't mind having is always on option and a little spectrum analyser on the display haha
