TYATYA
Ru6 performance scale up with digital transport.Has anyone listened to heavy music on RU6, isn't it too smooth for extreme metal?
I can't say for metal but I find for rock, the cymbals / crash and snare drum felt a little bit polite for me. Most notably with snare drum. Kick drum is also slightly softer than how I'd like. But guitar sounds good though. Just snare drum you don't feel the metal coil under the drum.Has anyone listened to heavy music on RU6, isn't it too smooth for extreme metal?
Do you find a touch more edge to cymbal hits (and snare hits too I guess) in OS versus NOS? I tend to always listen with NOS but I remember when I first got the RU6 noting that OS came off a bit more aggressive. I need to revisit OS to confirm, though.I can't say for metal but I find for rock, the cymbals / crash and snare drum felt a little bit polite for me. Most notably with snare drum. Kick drum is also slightly softer than how I'd like. But guitar sounds good though. Just snare drum you don't feel the metal coil under the drum.
LOL I think I'm picky on how snare drum sounds and most higher end dongle dac tend to over smooth it. Somehow the cheaper dongle dac tend to do this better since it's less smooth. It's kind of like Grado where it's more rough / coarse but works better in genre that favours that roughness / edginess.
RU6 is not as smooth as W2 / W2-131 but smoother than Dragonfly Red.
I didn't test OS too much I just remember NOS sounded more analogue and OS sounded more like other delta sigma dacs so I just stuck with NOS lol. But I do remember reading that people mentioned OS is a little bit more aggressive than NOS.Do you find a touch more edge to cymbal hits (and snare hits too I guess) in OS versus NOS? I tend to always listen with NOS but I remember when I first got the RU6 noting that OS came off a bit more aggressive. I need to revisit OS to confirm, though.
I have owned both dx160 and ru6 and still own ru6.How does it compare to DAP such as Ibasso DX160? I was just wondering because I went for the DX160 instead of the Cayin RU6
Power basically... and amplifies the good and the bad out of the RU6~ I only have the WA8 to try it with though so YMMVDoes RU6 scale with good power amp, if so in what qualities?
I found zero difference in audio quality of 3.5 vs 4.4
A/B test, I myself switch the toggle and even through, I heard nothing difference at any means.
So I must unplug a channel of RCA to verify I did not bunco myself
My guess is because RU6 is not technically a true balanced dac. What I mean is that it only duplicated the signal at the last stage (stated by Cayin also there is diagram on 1st page of this thread).
So you probably get more power but otherwise identical source signal?
Other "true balanced" dongle dac split the signal earlier in the steps. My guess is that in order to do "true balanced" they need to double the resistors which make the size limitation impossible?
Stay updated on Cayin at their sponsor profile on Head-Fi.
After A/B Ru6 2 output 3.5 and 4.4, I seriously try A/B Ru6 against SP1K output.
Insane? NO!
I know, I heard Ru6 by HD800S from day1 I got ru6 and found something special to draw me to the music.
@Andykong said SP1000 wins every meaning.
I today said ru6 wins SP1000 when feeding to the amp hdvd800.
(Both bal, se, all dac filter mode in AK)
Ru6 sound liquid, wider imagine (something like adding echoing but actually not), holographic, same clarity, nothing hash.
Idk why when UAPP shows a same moment on my smp(connect to ru6) and on SP1000, output of ru6 is much sooner (apprx 2 seconds!).
(All dsp off on Ak, try all dac filter include short delay)
Ak fw1.66cm
Super Slow roll off : the most close to ru6 but still 2D, not 3D like
Short delay Slow roll off: the most use of mine for directly drives hd800s. But sound worst when feed to the amp.
Mid imagine locate and focus at center, lacking detail overal
Short delay Sharp roll off (default mode): focus mid on center, forward, clarity than other modes, but I feel harsh abit.
Ru6 sounds something mix of Super slow roll off and Default mode but in 3D imagine.
Mid from ru6 so special! 3D, stay backward a bit, wide, realistic timbre.
Update: uapp is something wrong on AK.
Test with Default music app of AK again and I update later
I compare again Ru6 vs AK SP1000 by various include:
-Bal or SE
-Which App and which dac filter
-OS or NOS
I found there's a combination makes me answer wrongly which device is sounding. That is when 2 devices sound identically, happen when AK in SE output + Default player or Neutron + Short delay slow roll-off filter, while Ru6 in Os mode (3.5 or 4.4 doesnt mater).
In 2.5(bal) and using short delay sharp roll off mode, AK wins with more 3D imagine and resolution. If it got 5 point, Ru6 will be 4.5
Luckily I found old version of Uapp is not good on AK from this comparision.
On THAT Uapp version I did not found a case AK sound better than Ru6, just approaching.
Super slow roll off sound worst on AK.
Slow roll off is 2nd worst, for feeding to headamp, but I prefer using it to drives directly a headphone.
Ru6, a really impresive toy
Just PO from RU6 into WA8... background is still black, which is impressive considering it isn't a pure LO. However I'm finding this pairing a little too warm for the IE900 I'm using.
I suspect this is an issue similar to the one I have been having with the iPhone maximum power output over lightning. I am not 100% sure but I feel like OS uses more power and NOS uses less power. Thus, when I was having clipping issues when playing Tidal Masters using my iPhone, it would always happen more frequently in OS mode than in NOS mode. As an example, when I play a bass heavy track on Tidal (The Weeknd - Starboy) using my iPhone, I could induce clipping in OS mode in High Gain at a volume of 60, but in NOS mode, I could induce clipping in NOS mode at High Gain at a volume of 74.
Try playing with the volume settings, playing with the Gain and maybe you'll find you have a similar issue.
As an aside, Penon Audio informed me that their Lightning - USB C cable is 5V and 200mAh so it shouldn't be the issue. Butttt I splurged and bought the OEAudio OTG cable that many have recommended. Will update the group when it arrives and see if this resolves my clipping problem.
Honestly, it isn't a huge deal as I don't listen to my music that loud and the Meze Liric is quite efficient but it just sorta bugs me that I can't use the full range of the wonderful RU6!
Exactly what I'm doing currently. 3.5mm out to WA8 which also only takes 3.5mm in. Thankfully still a very black background, so while it isn't a line-out, it is more than useable~ Enjoyable even. A very musical and powerful combo~I have steer users away to use RU6 as DAC to portable amplfiier becuse it doesn't have a line out, and the noise characteristic of R2R DAC is technically not ideal for "pseudo" line out application. However, I did try to connect RU6 to C9 to test how it work out. On top of using the pre-amp input mode of C9, which was frequently used with DAP without a proper line out, I noticed that when I connect RU6 to 3.5mm line input of C9, the quality is actually better then using 4.4mm balanced line input of C9. Therefore if someone really want to sue RU6 as line out to external amplifier, I'll recommend you to stay with single-ended connection.
