Hyde00
My guess is because RU6 is not technically a true balanced dac. What I mean is that it only duplicated the signal at the last stage (stated by Cayin also there is diagram on 1st page of this thread).I found zero difference in audio quality of 3.5 vs 4.4
A/B test, I myself switch the toggle and even through, I heard nothing difference at any means.
So I must unplug a channel of RCA to verify I did not bunco myself
So you probably get more power but otherwise identical source signal?
Other "true balanced" dongle dac split the signal earlier in the steps. My guess is that in order to do "true balanced" they need to double the resistors which make the size limitation impossible?
