Cayin's 2023 Chinese New Year Holiday Announcement
The Chinese New Year is around the corner, and all teams in Cayin will have their yearly holiday starting 14th January 2023, and we shall resume operation on 30th January 2023.
All members of Cayin wish everyone an amazing Year of the Rabbit.
Dear Andy, we do wish you a happy New Year. May last year‘s time out be fruitful for you personally. And - most importantly - may you all stay healthy.
So I finally connected up the N8ii to an amplifier... but because it is an older model it only has analog inputs. It appears...well obviously...the headphone output has the choice between Tube & SS but the line out does not. You can choose between (a separate) three gain L.O. settings which range from 1 volt to 2 volt output... but nothing else is affected that I can determine. It doesn't do the four second pause as it switches between modes--which tells me its not doing it at all..
Is it true you only get the (tube) option with the headphone out? What other "compromises" are made with the Line Out jack?
I guess that's why Cayin also sells a tube integrated amplifier
Does anyone know if the usb-c digital output works the same way?
Is anyone able to connect their N8ii to enterprise wifi at work (WPA2/WPA3 Enterprise)? I can't get it authenticated to work wifi. Shanling M9 was able to connect to work wifi.
Update:
I was able to connect with the following settings. Android makes it way too complicated for this kind of stuff.
1. For EAP method Select PEAP
2. For CA Certificate or Certificate Select Do Not Validate or similar
3. For Phase 2 authentication Select MSCHAPV2
4. For Identity Enter our username
5. For Anonymous Identity, leave it blank.
6 For Password Enter our password
I'm sure I echo a lot of people' s sentiments here when I send my thoughts and condolences to the victims of the horrible mass shooting in LA's predominantly Asian community!
Hello!
Has anyone found a problem with gapless playback of tracks?
This is very difficult to find out, since it requires having albums with a lot of high-resolution tracks and at the same time recorded without gaps.
As a rule, such a problem has a certain sequence and systematic nature.
For example, noticeable stuttering or barely noticeable cuts can occur when listening to four, six, eight, twelve, and so on tracks in a row at a resolution of 24/96 or 24/192.
Is it somehow related to the buffering of files in the player's RAM?
I noticed this already with firmware 1.6. But it is quite possible that such a problem can be with earlier firmware.
Again, it may turn out that someone in a large music collection has only a few albums that allow such a problem to be detected.
Hello!
I use Cayin Music app and HiBy Music app. Basically it's the same player.
It is likely that the problem with gapless playback may occur due to their incorrect operation.
I am listening to a large portion of live recordings (jazz, classical), where applause goes across track boundaries. Amongst them, I should mention Grateful Dead live recordings, who used to segue something like three, four or five songs in a row. In particular the latter would enable one to hear a fault in gapless replay most clearly?
But, as I said, I didn‘t notice s.th. like that yet with Neutron, UAPP, Qobuz. I‘ll keep watching …
Picked up the updated Cayin N8ii case from Andrew at Musicteck. Big improvement over OG stock case with butter soft leather, magnetic closure for case, good fit, side slot provides easy access to the microSD on the side.
Overall very nice though I find the Dignis Pantheon case for N8ii does a better job of venting heat for long time listening.
