1/ Heat!
Is it an issues ? Yes, heating up is always an issues for any devices. What causes the heat generation ? The components. The more powerful the components, the more heat it generates. Take AK SP2K for an example. Will it heat up ? Certainly !!! What components make it heat up ? Dual AK4499EQ as the most powerful Desktop DAC chips. Why ? Because it is classified as Desktop and never portable. So, you want it to be cramped inside a portable player ? You get heat, period. Ok, and that wasn’t all there is to it. The AK SP2K doesn’t even activate all 4 channels of the DAC chip.
Now, Shanling M8 is another player that heats up a lot, why ? Because they use the same powerful chip, but why a lot though ? Because it is also using all 4 channels, which means using the desktop chip in the most demanding manner.
So, you understand the heat ?
Now, neither of those 2 player is having any discrete amplifier.
2/ amplifications, have you ever heard of or used class A amplifier ? If you had, then class A amplifier always generate so much heat … why ? Because it is only 20% effective. That means almost 80% of the energy are wasted as heat
Now, class A/B, which is most of the Opamp chips are based on, and they also generate heat too, why ? Because they are only 40-50% effective. And so 60-50% energy becomes heat.
Ok, on top of that, have you ever used a discrete amplifier ? That is right, being discrete, they generate even more heat. Why ? Because each components have it own tolerances, 5% to 20%. That means they will waste energy up to 20% as heat.
3/ Ampli à lampes… Je suis désolé, mais avez-vous déjà utilisé des amplis à lampes qui n'ont pas de lampes à chauffer ? Alors… voilà, vous l'avez… les tubes vont également chauffer.
Bien sûr, les lampes Korg ne chauffent pas autant, mais c'est toujours à lampes, juste pour être des lampes
Enfin, les puces ROHM DAC sont des puces de bureau. L'amplificateur à l'intérieur du N8ii est discret. Il a la classe A, et il a la classe A/B… alors, combien de ces technologies sont déjà connues pour générer de la chaleur ? Ensuite, vous aurez également des tubes Dual Korg. Oui, vous avez bien lu… il y en a 2X. Les avez-vous déjà vus dans un portable ? Sauf N8ii ?
Alors, vous voulez parler de chaleur ? Dites-moi, s'il vous plaît, quel autre lecteur peut être aussi portable, avec un double tube Korg, avec un ampli discret de classe A ou A/B et un fonctionnement plus froid que le N8ii ? S'il vous plaît, pour le bien de cette conversation, continuez.
Ok, vous dites problèmes de charge ?
En quoi est-ce un problème lorsque le joueur essaie de se protéger et de protéger son propriétaire ? Étant donné que la température a suffisamment augmenté, la batterie à l'intérieur pourrait être endommagée et le propriétaire pourrait être en danger ?
Problèmes d'épuisement de la batterie ? Comme quand il est vidé et ne revient pas en ligne après 30 minutes ? Avez-vous essayé vos téléphones Apple de cette façon? S'il vous plaît, dites-moi combien de temps il faut pour se réveiller ?
Les seuls problèmes sur lesquels je suis d'accord, c'est que cela m'a ennuyé, et c'est ainsi que le N8ii n'est pas livré avec un chargeur. Je n'arrêtais pas de dire à tous ces fabricants de DAP d'inclure un chargeur officiel, afin que les gens soient moins frustrés de charger leurs propres lecteurs. Oui, nous avons peut-être déjà eu le chargeur, mais juste pour une preuve infaillible, incluez un chargeur qui se charge juste. C'est ça. De plus, je recommande à Cayin de publier les cas de lecture/charge simultanée, qu'il doit être refroidi avant de pouvoir le faire. Parce que pendant le fonctionnement, le lecteur chauffe, il peut entrer en mode de protection et la charge ne se produirait pas.
Cayin, au lieu d'inclure le boîtier, vous auriez dû inclure un chargeur. Cela aurait résolu tant de vos problèmes
Enfin, aux personnes qui se sont plaintes de la chaleur. Essayez-vous de demander une glace qui n'est pas froide ? D'accord,
