@Andykong. I see that you will have the new Cayin tube amp and N8ii for demo at CanJam Singapore. I can't make it, so I hope to hear the tube amp at CanJam SoCal if anyone will have it there.
I would love to use my N8ii as a source to demo that amp. What would be your recommended cable type and settings to demo it?
Would you go Line Out with the N8ii with a 3.5mm to RCA cable?
I ask because I tried to use my RS6 as source at CanJam NYC and it sounded terrible with a USB cable into a DAC. Or, Line out to dual RCA.
If I wanted to demo a solid state AMP like a Ferrum Orr, would it be best to go 4.4mm balance out to dual 3 pin XLR input on the Orr? I have no idea if these are really dumb ideas or not. So, asking for some recommendations based on technical considerations.
All I know is that I gave up using my RS6 and instead ended up using my iPHone with a CCK adapter to go USB into a DAC and that actually sounded best. Or, with a Hugo 2 going RCA to RCA to a tube amp. I would rather use my N8ii as a source to demo everything so I would either need to go USB into a DAC or same analog interface into an amp. Can you provide some suggestions?
