davidmthekidd
- Nov 14, 2015
Has anyone tried the N8ii with the MDR-Z1R????
Oh I was talking about DCA Stealth, which is 86dB so bot as easy to drive as Arya StealthI actually just traded my Arya Stealth for the HE1000SE, stealth was easier to drive for my N6ii-RO1 which actually is not as powerful as the N8ii, though stealth is 94db/watt, N8ii drives the Susvara also very well so you would have no problems with the stealth... Enjoy
We agree on this, I noted this in the initial findings I posted mentioning upper mids but I wouldn't have called unforgiving before I tested a bit more and pushed volume especially on the Elysium this was pretty clear. I am a low volume listener so right at home there with N8ii.Andd…I just realized why there are hot upper mid and or sizzling trebles. If there are the word of “Unforgiving”. Then there is no one doing as good as the N8ii. It is the best at being “Unforgiving”.
I guess it is a given because it is so transparent with one of the highest resolutions I have come across. No additional colorations. Therefore, chicken poops in = no chicken noodles out. While the N8II helps me enjoy a lot of my collections which I often overlooked, it also reveals what album were badly recorded, especially the vocal and it “windy Z,T,S,X”.
If I thought that previously ESS were unforgiving, then it isn’t anything against the ROHM and N8II .
Also, the N8II is excellent at low volume listening! Amazing! I gotta say. Not only that it still has that crazy dynamic and punchiness, but the airiness, details, extensions of the trebles are not attenuated (this is extremely hard to achieve). Normally it would either be the dynamic or the trebles resolutions or both that would suffer. However, to preserve the trebles body, details and airiness is extremely hard.
Finally, the combination of bad recording together with loud volume = Killer**** the N8II will deliberately spitting into your ears and that you can’t even tolerate it, in a sense that it is asking “you seriously listening to this craps ? Never realized it ? This is how I am going to help you”
Beside that, anyone else is seeing their Korg tubes light dancing on powerful bass ?
What's with the tools? You need a soundtrack to do some hunting and/or open a bottle of artisan beer?I find the sound coming out of the N8ii via the OH10s to be nice and thick, really going to try to enjoy it with all my IEM and HPs, besides some F1 and an offspring turning 10 that is, so likely not a lot. I do really like the case the Cayin came with, colour and feel are quite nice.
It means your 88.2Khz file is being downsampled to 44.1 because of the Roon app's limitation on Android. Basically you can't listen to any of you music library in Hi-Res format using the Roon app. Apparently there's some workaround using HQPlayer but I don't use Roon myself so someone more experienced might be able to shed more light here.This is Roon for me on the N8ii, haven’t a clue what it all means.
Fiddly bits mostly, and a light, fiddly bits are to fiddle with and the light makes the dark go away. I am more of a gatherer than a hunter and i do prefer a shandy to a beer!What's with the tools? You need a soundtrack to do some hunting and/or open a bottle of artisan beer?
yeah, that’s what i figgered, ah well, Roon is good to have as a backup to local, Qobuz and the like.It means your 88.2Khz file is being downsampled to 44.1 because of the Roon app's limitation on Android. Basically you can't listen to any of you music library in Hi-Res format using the Roon app. Apparently there's some workaround using HQPlayer but I don't use Roon myself so someone more experienced might be able to shed more light here.
I use Roon extensively at home as I have my whole music collection on my Synology NAS. If the 44.1 KHz downsampling limitation bothers you just directly use Tidal or Qobuz app on the Android hence I love this Android implementation on the N8ii. Just opened up a whole new world for us to tinker. Worst still just copy the music file to the microSD and play it local. 1 TGB MicroSD is good enough for me. I do find the sound is still acceptable since MQA works and quality is still good. Otherwise just install an app like HQplayer or Upsampling app and redirect Roon through this. Some apps can upsample to DSD 128 quality. I am not sure if Roon will be certified in the near future. I suspect it means paying them some cash for coding it to get it to convert to higher quality which in turns means the price of the unit might rise in the future.yeah, that’s what i figgered, ah well, Roon is good to have as a backup to local, Qobuz and the like.
i don't mind some Roon coming in like it does now, qobuz, Apple Music, tidal and the local files are quite nice to listen to as well... if I do a proper sit and listen I use a zen stream to a fido k9 pro using roon, works a treatI use Roon extensively at home as I have my whole music collection on my Synology NAS. If the 44.1 KHz downsampling limitation bothers you just directly use Tidal or Qobuz app on the Android hence I love this Android implementation on the N8ii. Just opened up a whole new world for us to tinker. Worst still just copy the music file to the microSD and play it local. 1 TGB MicroSD is good enough for me. I do find the sound is still acceptable since MQA works and quality is still good. Otherwise just install an app like HQplayer or Upsampling app and redirect Roon through this. Some apps can upsample to DSD 128 quality. I am not sure if Roon will be certified in the near future. I suspect it means paying them some cash for coding it to get it to convert to higher quality which in turns means the price of the unit might rise in the future.
BTW here is the link to installing the HQplayer. I use a Synology NAS and you can run an VM image on the Synology NAS.
If running as a VM
https://www.signalyst.com/embedded-install.html
On Windows
https://www.signalyst.com/quickstart.html
Roon supports HQPlayer you just type in the IP address of the HQplayer to direct it there via the Roon settings
You mean this? Just click into the song.Is there any way to check what res of music is playing? Since it’s not listed on the toolbar, first DAP I’ve owned missing that, rather have music quality over what amp I’m in since I can pull down the tool bar and check what amp I’m in but can’t check my music res. Any way to add that to at least the pull down tool bar?
Presuming no full mqa unfolding?
