FooFighter
Don't have N7 but from my experience with other DAPsi connected N7 to macbook pro by means of cayin cable this situation appears as dac and i don't hear anything. where am i wrong now? forgive me for asking, but I want stubborn N7 in all its main functions, I got it as a laptop and as a substitute for a desktop dac to complement my desktop amplifier and use it as a dac for my macbook pro.
- you might want to check N7 in the MacOS sound and mixer settings if it's selected as output device and some default bit rate is set
- you might need to use an additional usb hub to make it work (this was the case for several DAPs I used to own, nowadays usually using IPad Air with above mentioned powered OTG adapter or Ifi Zen Stream with only USB cable as sources which won't require an additional usb hub)
