Cayin N7: A Voyager of Unexplored Frontier
Apr 8, 2023 at 1:49 AM Post #873 of 2,072
I want to connect my DVD player with spdif output to my Cayin N7 to use it as DAC, I tried with Cayin spdif-Usb C coaxial cable, but I don't hear anything. Where am I wrong?
N7 does not support coaxial input, it only provides coaxial output, that's why you can't feed spdif output to Cayin N7
N7 only provides one digital input, USB Audio. If you must use coaxial input to N7, you need a DDC to convert SPDIF to USB, but that will introduce delay in your signal path, making it impossible to synchronize audio and visual signal correctly.
http://en.cayin.cn/
Apr 8, 2023 at 6:18 AM Post #874 of 2,072
Hi @Andykong !
Have you checked different Android music player on N7?? Power AMP is quite a popular app that has always worked smoothly on my Hiby and Ibasso devices but for some reason it doesn't work on N7, the advantages of Android are being able to use different Apps but in this case I have encountered limitations, you can check this please?? Thank you
Apr 8, 2023 at 8:58 AM Post #875 of 2,072
I’d also like to know if someone is using a BT remote like Chubby Buttons with the Cayin music app or Apple Music which I use quite a bit. I have a Sony DAP and you can’t use a BT remote other then the Sony remote. Thanks a lot.
Apr 8, 2023 at 9:07 AM Post #876 of 2,072
so I can't use my N7 as a dac for the cd player if I don't have a ddc? i am disappointed about this. instead, how can I exploit it with my Macbook Pro with Thunderbold 3 ports? do i use any usb c to usb c cable?
Apr 8, 2023 at 3:19 PM Post #877 of 2,072
End game.... pretty expensive though.
Apr 8, 2023 at 3:43 PM Post #878 of 2,072
Does anyone else notice a slight clipping noise between playing songs on the N7? I notice it with 3 different IEMs and 2 different players. On balanced it's on right channel. On 3.5mm it's more both.
Apr 8, 2023 at 3:50 PM Post #879 of 2,072
To be expected if you find it. And then think of all that you spent to get there!
Apr 8, 2023 at 4:01 PM Post #881 of 2,072
Unfortunately nothing is really mine 😞
I sympathize...i have Mentor for the next week, and I'm already missing it.
Apr 8, 2023 at 7:14 PM Post #882 of 2,072
I've found the Yamaha a bit stingy on Dave. No stinging on this combo? Apart of that really amazing clarity. Must be a dream with classical music.
Apr 9, 2023 at 12:47 AM Post #883 of 2,072
Apr 9, 2023 at 2:25 AM Post #884 of 2,072
May I ask what exactly do you mean by "stringy"?
They sound amazingly good, the tube adds some more body and timbre realism.
I rank them together with the Elite.
Apr 9, 2023 at 3:18 AM Post #885 of 2,072
Hello, I'm looking for a upper-mid end game for my Meze 109 Pro, the Cayin N7 seems to be an interesting choice. Should I buy a full-fledged stack (Bifrost 2/64 and ifi Pro Ican Sig come to mind) or just this small cute but mighty DAP like this?
