111MilesToGo
I‘m a bit lost. My N6ii has become unresponsive to any actions of mine on the screen.
I had not used it for maybe two weeks. Pressing the power button makes it boot up fine, it shows the two logo screens (Cayin and Never be the same again), then it ends up with the lock screen. Battery indicator is at 45%, WiFi is active, it shows Google Play updates.
However, I cannot unlock it at all. Swiping up from the home button, correct? (Have been on my iPhone for too long.).
Pressing the power button a bit longer lets the Switch off / Restart selector come up, but I don‘t get any action from it.
Pressing the power button very long let’s it shutdown, without any on-screen indication (Return soon or s.th. like this).
Pressing the power button lets it start fresh. Same unresponsiveness of the screen.
Please, help and advice needed. Ultimately, worst case scenario, I suspect the screen might have disconnected or is broken??? No signs of any bad treatment on the outside.
Thanks in advance.
EDIT: I hooked it up to its usual charger (tested for proper functioning first). Strange behavior: With the N6ii off, I don‘t get the pulsating home button and no little battery on the screen; no signs of life. Switching it on shows that the battery percentage indicator in the status bar goes up, from 45 to 50% within like 10 minutes. Still no screen responsiveness at all.
Thanks in advance.
