Hi, glad it was helpful.
Just as a prefatory comment on your remarks: clearly the C9 "out-specs" the WA8 on a number of levels. But the motivation of my review/comparison was not to assess which is ahead in this respect, but rather to assess whether they're a mutually edifying pair of amps to own (which I think they are). I've had the C9 since it was launched and continue to love it, and can't ever see myself selling it. But the one thing the WA8 that is different is actually offer a
tube sound. The C9 is an incredibly resolving amp, but if you're looking for a warm tube sound, it's the wrong amp. This is why I think it's nice to have both amps; they offer totally different tonalities and timbres.
On your questions:
- The battery on the WA8 is not user replaceable in the way the C9 is. Probably it can be replaced in the way a Mojo battery can; no doubt
@HiFiGuy528 might provide some clarity here.
- I'll do a sustained test on battery life today. Running now in USB DAC mode and will repeat test in LO mode.
- You'd have to test yourself for dynamics and staging. As I say, C9 has better micro-detail, better imaging, and separation; WA8 has more energetic dynamics with a larger stage.
- Yes, C9 is obviously more powerful. But as I say, numbers aren't everything. I recently had the FiiO M17, which is an excellent DAP. On paper, it's more powerful than the C9; in the flesh, the C9 outputs more power and generates more headroom with a 600ohm pair of headphones. They use different amp technology, so these variances are to be expected. The same is no less true of the WA8; it too can drive my 600ohm Beyerdynamics without issue. I understand
@HiFiHawaii808 has even driven his Susvara on the WA8 to an acceptable level. The BA300s - which I've had - doesn't even deserve mention here: it's worthless! It adds nothing; only 3db gain or something. I recommend people avoid it.
- Tube rolling is optional, not mandatory. The stock tubes are excellent and will be "enough" for the majority of users.
In terms of price, i's expensive but the one thing you omitted to say is that the WA8 is a fully fledged all-in-one device. It's not just a tube amp, it also has an excellent DAC implemented. I see it as being comparable to something like the Hugo 2 in this respect (obviously totally different performance and tech) but at the same level nonetheless.
In any case, worth demoing yourself. They're both great amps doing different things!
