hi. to those who have have E02 or experienced E02. how long does your battery last? mine is fairly new, been burning in for 5 days and i only got around 6 max 7 hours full charge. all my music files are aiff, iem used is sony mdr 7550 and low gain with volume around 30-35. is this normal? thanks.
Cayin N6ii, Unlimited Possibilities: a fully modularized smart DAP
- Thread starter Andykong
- Oct 6, 2013
Did you make sure you have the latest fw (https://en.cayin.cn/down1/show?id=13627)? and after you confirm, do factory reset and then try from full charge again.
i will try this and see if it's about the same or not. i do have the latest v2.3EN. thank you.Did you make sure you have the latest fw (https://en.cayin.cn/down1/show?id=13627)? and after you confirm, do factory reset and then try from full charge again.
Shinigami76
Yes E02 is a power hunger module. Normal last only 6-7 hourshi. to those who have have E02 or experienced E02. how long does your battery last? mine is fairly new, been burning in for 5 days and i only got around 6 max 7 hours full charge. all my music files are aiff, iem used is sony mdr 7550 and low gain with volume around 30-35. is this normal? thanks.
Shinigami76
R2R Have a better battery life
Iggnasty
Is it normal to hear a pop on the left channel when connecting earphones to the DAP?
- Oct 6, 2013
Probably a relay click.
SHOOTINGTECHIE
i do hear it sometimes, it feels a relay clickIs it normal to hear a pop on the left channel when connecting earphones to the DAP?
Taz777
Has anyone installed Roon Remote on their N6ii? It works fine for me, but I have noticed quite a bit of battery drain since I installed Roon Remote and when I’m not listening to music. I suspect theres a fair amount of background activity going on.
Is there any way to check exactly what is causing this excessive battery drain?
Wildcatsare1
Well, my R01 arrived, but still waiting on my N6ii main unit to arrive
- Nov 18, 2011
Looks like I'm joining the n6ii crew, well the Ti version so with R01... a few weeks but can't wait and will lurk here while I wait
Wildcatsare1
Join me in lurking about here, my R01 board arrived, now waiting for my main unit.
i followed twister6 advice and yes looks like it is power hungry and i still get close to 7 hours today.Yes E02 is a power hunger module. Normal last only 6-7 hours
- Mar 28, 2017
@Wildcatsare1 @Scuba Devils you guys are in for a serious treat. Definitely worth the wait!Join me in lurking about here, my R01 board arrived, now waiting for my main unit.
kel77
- Nov 16, 2015
Anybody else having problem to update the HibyMusic app on N6ii? https://www.facebook.com/CayinAudio/photos/a.299322053812361/1183358945408663/
I am using a n6ii-Ti. My HibyMusic app version is still at 1.6.0 and when I press the Update Check, there is no reaction.
Total: 15 (members: 0, guests: 15)
