Update on skipping
I’ve just tested offline Tidal downloads. There are some tracks I use because the singing begins immediately, thus it is easy to tell if there is an issue. These are:
‘Best of You’ by Foo Fighters
‘Help!’ By The Beatles
‘Suppers Ready’ by Genesis
‘Here’s The Tender Coming’ by The Unthanks
‘Carry on Wayward Son’ by Kansas
Every one of these skipped when I pressed on them to play.
I’ve just tested the SD card via Cayin music app and this seems to be ok, although I cannot say 100% yet as I want to load up some of the above songs to check.
Update on skipping: My test track for this issue is J.S. Bach‘s Italian Concerto, 1st movement, performed by the Jacques Loussier Trio on their “Play Bach aux Champs-Elysées“, CD 1, track 2.
Let me repeat myself: Listening to the T01 module via headphones, I observe the skipping issue with all three player apps, Cayin, HiBy, Qobuz. My music is stored on a SanDisk Extreme Pro Micro SD card with 1 TB capacity and 170 MBytes/s reading capability; only 6 GB out of the 1000 GB used up.
There is another test that I would like to do, but haven‘t found the required peace yet: What would happen if I / we were to take the digital output from our N6ii into another outboard DAC? Could be my Chord Hugo 2, of which I am sure it plays even the first fraction of a second when a digital signal comes in. We could utilize the USB-C output from the N6ii, or the S/PDIF embedded in the USB-C, ohe I2S embedded in USB-C.
This test should be very interesting, since I suppose it will eliminate the DAC/AMP module from the game. I suppose it will leave the player apps and a portion of the N6ii firmware in the faulty game. Again, please forgive me if that test has been done already; pls let us all know again.
Actually, this proposal came to my mind when I reflected on my past journey:
- I started out with an AudioQuest DragonFly Red USB-DAC. Simple and effective device, which I use still today for quick and dirty tests.
- Next thing was an Oppo HA2-SE USB-DAC. This one got returned to the dealer quite quickly, since - guess what! - it discarded a few seconds of music every time when I hit Play from stopped or paused status on the associated computer. I had been in contact even with Oppo California, but to no avail at all. So I bid farewell to it.
- Thereafter, I auditioned other USB-DACS, a.o. a Chord Mojo (not my sound). Anyway, I ultimately ended up with purchasing a Chord Hugo 2.
- The N6ii came last as a handy device, and it‘s an outstanding DAC.
Thus, I am reminded of step 2 of my journey by the current “skipping issue“ of the N6ii. Maybe it is interesting that the Oppo was just a USB-DAC, no operating system, no player apps.
Another test which could be done is putting the music files into the internal storage of the N6ii instead of an SD card as in my case. But I seem to remember that this has already been done by
@Deferenz? Nevertheless, I figure an SD card at 170 MBytes/s reading should be fast enough to fill a play buffer almost instantly.
Finally, I should like to express my sincere hope that Cayin‘s developers can turn to the skipping issue now, since the bugfixing for firmware 2.2 is off their chests. Dear
@Andykong, please let us know what‘s going on; if not now, then be after the 1st week of October break.
