How did you do conduct 'quick' A/Bing while having to switch out audio motherboards? Did you make all your comparisons with one DAP? Did you volume match? Also, 'my friend's hybrid multi-driver' is pretty darn vague. We don't know what the characteristics of the IEM are and don't know it's name. I'm sorry, but your impressions could be a lot more helpful with some basic level reporting on your methods.ok after about 90hours with e02 i did some comparison with e01 yesterday.
First let’s talk about e02 on it’s own, after burn in e02 start to warm up a bit, sounds to me like a01 but with improved separation and resolution.
However the sound is still not as holographic as t01, not to mention e01 in class a mode. And I generally don’t even consider t01 holographic...
I use my friends’s hybrid multi driver iem for the comparison, it’s much easier to drive than my a8000. With the same song(and same software:neutron), e01(class a)’s soundstage have much better frontal depth and it just have this holographic feeling to the sound(Not like a lot but enough for a mobile setup).without a hefty load e02 start to sound less impressive than before....the soundstage is very wide with much reduced frontal depth. Separation is better than e01 but that’s unnecessary, with a very horizontal sound stage it just not fun and very tiresome for your attention To constantly shifting from left to right. Transparency wise they are about the same level, e02 is slightly more transparent due to improved separation.
N6ii have very limited space for what they called ‘audio motherboard’ truth is it’s a mini-soundcard connected through pci with n6ii. The limited space is responsible for dac& Structure which is impossible to do any of those part to a very good level. But for a mid-fi dap n6ii is doing great, All of the Replaceable soundcard sounds relatively good on their own And they all stay in the same league. But amongst all those sound card i think e01 is the most unique and technologically complicated one. Implementing a full size 9038 pro is not an easy task, and you can hear the difference between 9038 pro and 9038 q2m after some quick ab test, 9038 is ultimately bit more revealing on micro details. I would very love to see an e03 with two 9038 pro and only line-out Output in the future.
E02’s advantage is it’s transparency and driving power also the line-out. And that’s it, if you don’t have a demanding headphone you don’t need e02. Just Go with e01
The statements on space on the 'audio motherboard' are not defensible. The modular nature of the N6ii moves off some components that frequently take up space, like the buttons, memory card, power components, and processor. Without comparing the internals of other DAPs and the representation of all components, you simply can't say what you are saying with any confidence. The statement about making an E03 with two 9038Pros is logically inconsistent when made directly after saying that you can't do much in the motherboard spatial format. The 9038Pro is incredibly power hungry and takes up a ton of board real-estate. The post you've made comes off like it's made by an expert to a casual reader. It needs far more caveats than have been put forward.
This is not to say that your conclusions couldn't be accurate, it's just that the uncertainty around them due to suspect statements and unreported methods is high.
