Cayin N6ii, Unlimited Possibilities: a fully modularized smart DAP
Apr 10, 2020 at 7:48 PM Post #4,007 of 8,192
A sound quality comparison between E01 in Class A mode vs E02 in Class AB mode would be interesting.
Hmm, why not AB vs AB?
Apr 11, 2020 at 1:17 AM Post #4,009 of 8,192
I would expect AB to AB to be better on the E02. If AB on the E02 was better than A on the E01 then that would be amazing.
I only use AB on E01, which I like quite a bit more than A?
Apr 11, 2020 at 1:52 AM Post #4,010 of 8,192
I think it won't be a direct conclusion. I use class A for Solaris, as it sounds more sibilant on AB mode, whereas u12t sounds good on the AB mode and not on A! I just hope that sonically E02's AB mode is better than E01. That will make the purchase really worthwhile!
Regards,
Vishy
Apr 11, 2020 at 2:01 AM Post #4,011 of 8,192
Regards,
Vishy
I will be selling all of my other cards once I get E02 other than A01 (mainly getting it due to its better battery life vs E01)
Apr 11, 2020 at 2:24 AM Post #4,012 of 8,192
I will definitely think about it brother, I too have the E01 and A01 for now, but then I am not very sure if the E02 will be an outright winner, as E01 uses a 9038pro chip Vs 9038Q2M on the E02. However it all boils down to implementation! But I also trust Cayin with this as they have done a good job so far, at least imo! I will buy it hoping they have continued the good work on E02 as well! I am eagerly waiting for the lockdown to end and E02 to reach me, as I have planned to get the oriolus BA300s as well as hum-ma1b to use with E02! I just hope all of these combinations turn out to be as awesome as I think they would be!
Cheers,
Vishy
Apr 11, 2020 at 3:53 AM Post #4,013 of 8,192
Technical Specifications of Cayin E02 Audio Motherboard:-
> High-performance Dual DAC setup, featuring dual ES9038Q2M DAC chips.
>Four Way I/V Conversion.
>Four Way Discrete Component Powerful Amplification.
>Output Power PO:- 600mW at 32 Ohms load, 137mW at 150 Ohms load, and 69mW at 300 Ohms load.
>Three Level Line out mode, High, Medium, Low.
>Output Power LO:- 4.1V @ 10k Ohm load, High.
3.2V @ 10k Ohm Load, Medium.
2.1V @ 10k load, Low.
>THD+N: 0.001%.
>Dynamic Range: 121dB.
>Signal to Noise Ratio: 121dB.
>Separation: 106dB.
>Battery Life of up to 9.5 hours.
Apr 11, 2020 at 5:36 AM Post #4,015 of 8,192
Wouldn't listening to it first make sense?
Apr 11, 2020 at 6:23 AM Post #4,017 of 8,192
battery life on both are 9.5h?
Hmm I have been getting quite a bit less with E01; I also found it doesn't go loud enough when used with my Utopias.
Apr 11, 2020 at 6:24 AM Post #4,018 of 8,192
Certainly. I very much look forward to @twister6 's review.
Sadly, heading out for a listening test is next to impossible in the current environment.
Apr 11, 2020 at 6:44 AM Post #4,019 of 8,192
I'll be reviewing E02, but won't have E01 for comparison. I've got a T01 coming with the N6ii shortly. E01 would be nice for comparison. I've no interest in A01, quite warm sound just isn't my thing, generally.
Apr 11, 2020 at 6:54 AM Post #4,020 of 8,192
Do keep us posted!
