x RELIC x
This is new to me, and is contrast to my own experience, so this is possible that an one-off situation.
Please try to copy the songs to the Internal Memory and repeat the process, if the problem disappear, that this is likely a TF card related or compatibility problem. If the problem remain unchanged, then we'll need to check with the person before and after you in the tour, if problem is consistent, then we probably need to recall the tour unit for a close examination.
Sorry Andy, I don't have the tour unit anymore. I did use the internal memory as well as the TF card. It was definitely a headphone jack issue and that particular tour unit was eventually replaced for the other members on the tour. I documented it in the PM'S with the tour members, and the member before and after me had the same issue. Funny thing is it would work fine for a while and then it would start acting up. This happened with multiple headphones and my IEMs.
I don't think it's a common issue to be sure or else you would definitely be hearing about it from many others. It was quite annoying. I'm sure EmpJ has already contacted Cayin about the issue. With all that said, overall it was a great unit to demo and review.
