I have no sound in mixcloud. How to solve a problem?
Firmware version 1.4en. In the foobar2000 and Neutron sound works.
After a lot of research I have sort of dwindled my DAP choice down to this as far as features/price goes. Sabre based is a requirement for sure as well.
So do we have a general consensus on this thing? Pro reviews look rather decent but Amazon reviews paint a pretty mixed bag of reliability, software bugs, etc. I mainly plan to use it for local SD music of the more MP3 variety and USB DAC for my PC.
Anyways, I guess just a yes or no if I should get one lol! Thanks!
For your use my main concern would be the weak and plastic 3.5mm jack, which I doubt will last for years in regular use. Some have had it fail after a few months, and mine is considerably looser after 8 months, and I try to minimize insertions. But there's the 2.5mm as backup for when it fails.
UX is pretty bad, but that's mainly for Spotify use. For Mp3s it's not awful. Buggy software, sure, and Cayin sometimes gives weird or no reasoning for retaining "features, not bugs."
Apparently the audio quality can't be beat for the price, and it's definitely good enough for me.
Hi, does mixcloud work on your cell phone? Could you please send your mixcloud apk to community@cayin.cn to me for a test?I have no sound in mixcloud. How to solve a problem?
Stay updated on Cayin at their sponsor profile on Head-Fi.
Yes, mixcloud works on Nokia 6. I downloaded this application from Google Play Market. I don't know how to get apk file.Hi, does mixcloud work on your cell phone? Could you please send your mixcloud apk to community@cayin.cn to me for a test?
About noise in headphones when player is loading, to Whom It May Concern I can provide the following facts.
1) Firmware 1.4 makes things better - less hiss is audible.
2) My Falcon C - high sensitivity, low impedance, mostly affected by issue.
2) Xiaomi Mi In-Ear Pro HD - average sensitivity, 32ohm impedance, affected by issue but just forMy f second hiss.
2) Audio-Technica ATH-M50x- average sensitivity, 40ohm impedance, hardly audible.
So the issue is audible with My Falcon C those are really super sensitive ones, but they sound great even with my phone so I an fine.
Most likely not OI related if it matches with the 1/8th. The noise floor can also cause hiss. The problem is that there is no standard in how that can be quantified making its inclusion in specs useless.I have the same issue with my massdrop+ iems(10ohms) which are very sensitive as well. I've noticed running it in audio priority mode reduces it more, but when streaming it's really noticeable. I also have a 3.5 TRRS cable I use through a 2.5 TRRS adapter with the same issue.
I don't have this issue through my HD6xx or HD58x.. All 3 setups running out of balanced 2.5 so it does seem isolated to very sensitive IEMS which is surprising since the output impedance is 0.6ohms.
Dear Susan, did you put dual cards into the N5ii? If yes, this problem is a known issue and you can see our reply here:https://www.head-fi.org/threads/cay...tal-audio-player.862763/page-73#post-13991523
By the way, I understand your frustration but still appreciate your patience and kindness! We are still trying our best to work on our firmware. Hopefully the problems can be settled quickly. Finger crossed!
I havent seen any N5iis reviews indicating whether it hisses with senstive IEMs tbh. I know that N5ii did have some hiss.Agreed, but something had to change. Colors had the exact same setup not too long ago and did not have any issues from what I remember? He was using the N5ii+massdrop iem+Ares 2.5 cable, but I don't think there should be a difference with the cable from my testing.
If anything, N5iiS should have a more black background with the internal hardware update.
Im terms of hiss, it's always subjective to the person. Some can deal with it some can't. Case in point, I just upgraded to the AK SE100 and I just couldnt make it hiss when I demo'd it with the Zeus R which is in the high end of senstivity. I did some late night listening when my house was dead silent and it was only if I played something and turned the volume down to 0 that it hissed, which to be honest would normally not happen.
