- Nov 16, 2013
Yup, i recently did deactivate the animations in android developer menu. I'm not sure i noticed any real improvement since though. One thing for sure is that it didn't change the lag after pressing play/pause button. Might be interesting to hear more about this issue from official Cayin people (eg @Andykong ?).
And again, i mention that i have the N5iis version. I don't know which model have other users in here complaining about UI being slow (as this thread is apparently for both units), but UI response is globally quite good to me. Except of course for the lag with play/pause/equalizer and the covers re-drawing. And i think it's important to consider whether people have the N5ii or N5iiS as the latter has 2Gb ram instead of 1Gb, which might explain why N5ii owners encounters maybe more slowness with UI...
having 64gb internal storage in the N5iiS is a big advantage for Spotify
If you only use the unit to play music stored on the music, its at most "mildly buggy". More like laggy.
But it sounds great.
Now if you want to feed a Mojo, or run apps, things get a bit stickier and you would need to run a search.
So the answer to your question really comes down to your use case. It is, in my opinion, a bit underpowered in terms of CPU/Memory.
yeah, the N5 is more like an ugly duckling in terms of the UI lolinteresting points
interesting points you raised up there,I actually had a chance to choose it (N5iiS) and the Hiby R6, used them both for a week, in the end,
I preferred the sound of the Cayin, hard to describe it but it sounds more 'alive/bright'? the UI on the R6 is super fast though the other con on the R6 is the 32GB internal memory, I experienced the Spotify re-download issue on the R6 when I saved the offline data on the external card, good thing the N5iiS has 64GB
the perfect DAP for me at this price range would be the sound of the Cayin and the UI/Bluetooth capability of the R6
the N5 is literally like the beauty and the beast![]()
We tested the N5ii during the prototype stage and we find the UI responded satisfactory. What we didn't test is a big music library with lots of album art, and when third party applications are in placed. We have to admit that our unique approach to design the N5ii as a music payer instead of a generic Android device with a custom music app has make things more difficult as the default Hiby App is always loaded, hence eat up some of the RAM permanently. 2GB RAM released a lot of pressure on internal resource management, so we are aware of this and probably won't be taking this route again if we were to develop Android based DAP again.
When we were drafting the N5iiS transition plan, the budget only allow us to pick one "upgrade" out of two options: increase RAM from 1GB to 2GB Ram vs increase internal storage from 32GB to 64GB. I voted the later because the additional internal storage will benefit the offline playlist of Spotify directly (upto 3300 songs, so 32GB is marginal, 64GB is straight forward) while others prefer the RAM option because a sleek UI response will improve the User experience, especially when third party applications or large music library are involved. Finally we included both at the same budget. These upgrades won't affect the audio performance, they are more related to User Experience. As mentioned in previous post, Cayin devotes to the Audio Priority thinking and we put all the resource (and budget) to facilitate high quality audio playback, end up with exactly what have been commented here: best bang for the buck on audio performance, but lacking behind in user experience. Sorry, these are hardware based constraint, I can only hope the extraordinary audio performance of our DAP will compensate for the laggy experience.
Stay updated on Cayin at their sponsor profile on Head-Fi.
