seanwee
- Jun 9, 2015
In light of TBomb06 supposedly flawless N5ii, I have decided to run a week or fortnight long test of the N5ii.
I shall be resetting my unit (goodbye playlists ) using every single reset function possible (both software resets and recovery mode resets).
I'll use the N5ii unaltered for the first 1-7 days and if it runs flawlessly, I will download apps one by one to see if any one app is causing issues. Passing that, I will enable WiFi and Bluetooth to see if they will affect stability after use. Finally, I will connect it to PC and copy over some files. (maybe the data management of the N5ii gets corrupted when copying?)
I will not be touching the smart clean function. Its possible the "smart" clean has been cleaning away some essential processes which are important for stability.
I'll be using the same 2 microsd cards I mentioned in previous posts.
Edit : I'll also test out the eq and other bells and whistles to narrow down the cause of the instability.
