This device has a lot going for it, the design choices are very well judged.
I was torn between getting an all-in-one Android DAP and a DAC/amp, and this is... both?
Android DAPs, if properly specced, bypass the Android mixer which is the most destructive aspect of modern streaming audio. But they all have major issues - either battery life, RF interference, no bypass for the Android mixer, or a 3-versions late implementation of Android. Also none will let you stream out of Wifi range (or then via a Wifi hotspot on your phone, itself streaming using cellular data, at which point we‘re pretty far from seamless, easy interfacing).
This echoes what has been said very well by
@nanaholic - I disagree however that making the perfect Android DAP is impossible, in fact the LG phones come mighty close.
A dedicated DAC/amp is nice but it’s just a brick by itself, although I appreciate how iFi and Fiio made an effort to include wireless support.
After spending several TOTL cans’ worth on Bandcamp albums I never listen to, like many others I turned to streaming for 99% of my music consumption - even for things I’ve bought, I’ll just add them into my Tidal library when I can find them instead of listening from an SD card. Though I agree the copyright-dictated removals on Tidal are a huge pain.
Cayin has smartly engineered the N3Pro so it works quite perfectly for people who stream, without directly being a streaming device. It acts as a turbo-charged BT receiver on the go, and a USB DAC/amp for semi-sedentary use - but with a real screen! And Hiby link. Many new DAPs do that too but Cayin have really cut on what matters least in this context; the big high-quality screen on the hardware side, and on the software side the whole Android implementation, then the compliance nightmare, and making sure specific apps like Tidal, Amazon, Qobuz are properly supported.
That has let them double down on audio, and I can hardly believe what they have achieved. My desktop DAC/amp works the same, with tubes as a buffer and transistors for output, and it’s a best-of-both-worlds scenario.
Also Raytheon tubes count among the absolute best NOS. There must be some pretty wild stories paving the road to discreetly collecting 40.000 tubes.
