Dax7
UAPP what it is for ? My player seem to be working fine
It's a 3rd party apps if you don't want to use the cayin or hiby apps to play music. It has more tweaking function and shows more information about your music (bit rate, etc.). It's a paid apps though.UAPP what it is for ? My player seem to be working fine
Paid once a few years ago. Still working on all players. Any problems getting fixed in short time.It's a 3rd party apps if you don't want to use the cayin or hiby apps to play music. It has more tweaking function and shows more information about your music (bit rate, etc.). It's a paid apps though.
Are other users able to reverse the back and forward buttons?Settings > System > Fn Function Key Settings > tap Flip Vertical to reverse back and forward buttons. Key Lock = default.
Mine didn't work either. I am also on 1.3Are other users able to reverse the back and forward buttons?
When I click on Flip Vertical it does absolutely nothing to the back and forward buttons... Why on earth is something like this simple task so difficult and actually impossible for me to do?
I done a factory reset and a fresh 1.3 update with clearing the cashe before and after but this all made absolutely no difference which is Extremely frustrating to say the least...
its not required for standalone qobuz or tidal ?It's a 3rd party apps if you don't want to use the cayin or hiby apps to play music. It has more tweaking function and shows more information about your music (bit rate, etc.). It's a paid apps though.
Many Thanks. So it's not just me then... This is something that definitely needs fixing as I absolutely hate the back button beside the power button...Mine didn't work either. I am also on 1.3
Also Volume in the top left corner is not displayed correctly when it is changed in Tidal and other apps.Many Thanks. So it's not just me then... This is something that definitely needs fixing as I absolutely hate the back button beside the power button...
Hands down, the best and most authentic review i've red, the effort shines through.Here it is friends, my full review of the brand new UM Amber Pearl IEM! This is a share from the Watercooler, but I thought you all would like to read it as well. It was big one for me, quite a lot of work went into it, so I really hope you all enjoy!
You can check it out here.
Great and very honnest review. Congrats...Here it is friends, my full review of the brand new UM Amber Pearl IEM! This is a share from the Watercooler, but I thought you all would like to read it as well. It was big one for me, quite a lot of work went into it, so I really hope you all enjoy!
I’m so glad you liked the review, it was a doozy to write. I’d like to try the N30 combo at some point, it’s supposed to be fabulous. Unfortunately it’s way too big for me to consider as a daily user, I need something pocketable.Great and very honnest review. Congrats...
May be using the N30 as the source could have removed the last concern you still have about the AP sounding since AP is suposed to be tuned for the Cayin N30 ?
Now, as a happy owner of a N30 AP Combo, I am very interested by your Cable recomendation. Initially I was considering upgrading to the BA YATOMO Ultimate (4W) but your description of the synergy with the RSD CF intrigueded me.... I guess this is this purple cables: the Fantasies Copper at $ 3.380 ? Did you buy it direct from Rhapsodio ?
Also, in another thread I think you mentioned that the EA Chrion 8W is "fantastic with the UM AP". Will you recommend it over the RSD CF or BA Yatomo or Shiro ?
thanks again for all the valuable information that you bring to us...
