I purchased an N30LE a few weeks back from Hifonix which was from a new shipment of re-baised units and I too have the same Mobile Radio issue. When I checked there now and it says 41% but when you click on it, it says no usage from last full charge. The thing I find strange is it's showing HiByMusic has been used for 5 hours 56 mins but only used 1% usage...Sorry for bothering you guys, but the battery drain on my N30 is still persists.
Can you check on your devices under Battery Usage if you have the process "Mobile_Radio" running.
You go to Settings > Battery > Battery Usage
I think Battery Manager bellow should be turned on to be able to monitor the Battery.
As you can see in the picture bellow, the process Mobile_Radio drains more battery than 3 hours of Screen time. Which is a lot.
In relation to Mobile_Radio, WiFi at the bottom drains 1% battery for 7:30 hours of usage.
What i have found so far is this Link where the Mobile Radio Active Bug is explained.
It baffles me that N30 is affected because it has no cellular radios inside.
I have tried a factory reset so far, but the bug is still here. @Andykong
I only use local files on my memory card and don't use wi-fi or bluetooth.
