groucho69
Someone asked earlier about battery replacement. I'm adventurous and opened up the engineering sample I've got. The battery is adhered to the backplate. The actual connection to the motherboard is a clip. It isn't soldered, so as long as this is the same in the final production units battery replacement should be pretty easy. The one thing to be wary of is that the back is held on by plastic clips, so if you're not careful you can break off some of the clips. Then the backplate won't be quite as secure, although the silicon case holds it together nicely. Not that I broke any of the clips on the engineering sample. Nope, not me...
I choose to believe you too.
