Lost Cosmonaut
What are those cans?
Yes, I was going to ask the same thing..
I read some of the other thread and the store link but I see no mention of the Carbon Black version and can't find one anywhere.
Liboer BH870 - carbon black (many other colors available including rose gold)
I hang around in the Asian headphone thread https://www.head-fi.org/threads/chi...-ear-headphones.822184/page-161#post-13812574
Thread has been slightly derailed tonight though.
A while back someone posted a photo of the other Liboers I have and I got them out of curiosity because they were really cheap but interesting. They turned out to sound really great to me so when I saw these 870s on amazon for £10 (I think the other colors were £35 and all were nearly that on aliexpress). So I grabbed them. Shared the info with the others on the thread and the remaining pairs disappeared from Amazon. the rose gold one can be found in the following link. If you click around you can probably find the other colors. It even came with a warranty support card.
https://www.aliexpress.com/store/pr...7058.html?spm=2114.12010608.0.0.8a25325Vp3m0W
Seems if you have a good driver (40mm Titanium in this) you can just about put it into any housing with possible good results.I cannot actually say that eveyone should get these. For me it was a curiosity thing and while I do love the sound, you can see by the handband that they are not the most secure on the head...slides a bit on my hair. The way they adjust is interesting. The metal slider part slides in and out of the cup itself. They fold and actually came with a nice case and a bag as well. Decent cable too. Well worth the £10...lol. Doubt the pads are can be replaced. This is the fun part for me... finding hidden gems.
This is what they look like on the underside of the cups.
Thanks nplateau for helping out by quoting my previous respond on the maximum file limit on Music Category function. I have submitted an optimization request to my team last Wednesday, literally immediately before I get on my plan to US (well, the plan was delayed for 6 hours, so I have some extra time to handle that promptly). From what I was told today, we can increase the title limit to 20,000, this is technically feasible and probably hitting the limit of N3 hardware (CPU processing power and RAM available for processing). The final availability will depend on actual testing after implementation. We cannot 100% guarantee that the feature will roll out in next firmware upgrade, we'll implement the feature but the final result will depends on actually testing, we do not want to downgrade our user experience and UI smoothness because of this feature.
For the meantime, you can access to all music files of your TF card by using the Music Library function of N3.
It is ok. If you come across it again, feel free to let me know.
Actually,this is a normal searching result because the search will not create a new list with selected item from the search. It will only bring you to the location of searched item in your list, and in normal searching practice, punctuation is neglected. Therefore when you search for S in your list, system will jump to the First entry start with S in your list, and in this case, the search direct you to .Sinch which happens to be the position at the top of the list.If you try out searching function of other app or contact list in your mobile phone, you should end up with similar results.
It would be interesting to know your EQs. I have so far found 2 EQs which I like. One isReally delving into the EQ section on my N3 today. It's great! I get to change the genre presets to "fix" my headphones without having to use the custom slot. Adding some vocal presence to the E-MU Teak, and adding some low and high end extension to the Oppo PM-3 really makes those cans pop, particularly the Teaks. Even better, both are so easy to drive I don't need to boost the gain, just the volume.
The reasoning behind it explained a few posts above. Another is everything set to -1 dB, except 8k and 16k, which are left as 0 dB. It's worth a mention that I use "Slow" digital filter.
