yes both 1/4" and 4-pin XLR can be used together to drive a total of 3 headphones at the same time.Can I use this amp to listen to both XLR 4-pin and 6.3mm unbalanced at the same time?
Cayin iHA-6 - US Tour and reviews
- Thread starter project86
uptildawn53
I don't think there is a mk2 iha6, Cayin don't need to release it. There is a mk2 iDAC6 which has significantly improved DAC AKM4490 to ESS9028PRO
The new upgraded DAC ( MKII ) is a nice improvement - More filters and more ways to configure them, better GUI for looks and navigating menu and it matches the stack nicer and runs cooler. The Cayin i-6 series is underrated, particularity the amp and now the newer DAC and no, there isn't a MKII AMP out that I'm aware of.
Hello
I have a question. Is there a manual in English up to idac 6?
uptildawn53
Thank you very much. I bought iha6 and now I am looking for good price idac6
uptildawn53
I don't know Dap. I have j.feng mx-1
I know, I just bought it a week ago
uptildawn53
Cayin iDAP-6 features
- Desktop network player that can supports all common digital file formats: DFF, DSF, SACD-ISO, FLAC, ALAC, WAV, APE
- PCM supports upto 32Bit/384kHz, DSD supports upto DSD256 with I2S, upto DoP128 with USB and DoP64 on other digital interface
- Comprehensive digital output options: USB, I2S, AES/EBU, Coaxial, Optical.
- Support file sharing through Ethernet or WiFi connection, can communicate with large variety of networked devices through Samba, DLNA and Airplay
- Can plug in SD card (upto 256GB) and USB storage (upto 2TB) directly
- Transmit or receive through dual Bluetooth v4.1, support Bluetooth remote control profile.
- Multi-lingua custom designed UI through 3.95” AMOLED screen, display Album Art, music information and control menu in a clear and effective presentation.
I play synology with NAS, I read that idap 6 has problems with upnp
The big difference between idac 6 and MKII in playing?
Rayzilla
I have a Synology NAS too. Do you play your music using their "Audio Station" app? I don't know if there are alternative ways or if it's even worth looking for one if there is no sonic difference. Could you share how you use your Synology.
I've been thinking about getting the IHA-6 and the IDAC-6 (I or II) as well. I like versatile dacs and I understand that the IDAC-6 is exactly that?
I don't have to idac 6. I have iha 6 + Audeze lcdx + soekris + J.feng mx1 + synology. J. Feng has his own player and everything works well,
Rayzilla
Thanks. Never heard of J.feng mx1. I'll check it out.I don't have to idac 6. I have iha 6 + Audeze lcdx + soekris + J.feng mx1 + synology. J. Feng has his own player and everything works well,
I bought on aliexpress
