You are referring to the output impedance of the i5, right? Below 1ohm is the correct figure for output impedance, this will affect the "damping factor" of a headphone system, which affect the control aspect of the headphone but not the driving capability directly.
According to the description of the product specification, i5 can pair with headphones from 8ohn to 300ohm, but this is a generic description and the result will depends on a lot of other factors such as sensitivity of the headphone or the technologies (driving requirements) involved. Having said that, we do have users using the i5 with 300ohm headphone such as HD800 in this thread, so the figure is correct to certain extend, but you just can't and shouldn't judge the driving requirement based on one simple figure.
Let me give you two examples for reference:
Audeze LCD-X Planar 22ohm 96dB
Ultrasone ED8 Dynamic 30ohm 96dB
While the specification of these two headphone are very similar, but the driving requirement is complete different. i5 can handle the ED8 fairly well, but is below satisfactory when deal with the LCD-X. So in reality, I do not recommend you use these figures as rule of thumb as-is. I suggest you list the headphones that you owned (or considering) and ask the opinion from the users, and ask if someone have actually tired this paring before.
