krude
Yes you'll need a good pre from May to HA6a (due to its lacking volume control), I use Bliss KTE for that.Fascinating, thank you for sharing this journey. It is very helpful for me. I’m building a desktop system in my head from scratch and your description at the end is where I want to get. Just as an aside – my personal analogy for an ideal outcome is “the bass player plugs his guitar not into his amp, but into my belly button instead”.
When listening to the Utopia – do you use the HA6a direct from the May or the Bliss in between? I interpret the above as direct, but did not understand for sure.
As for the Holo gear – do you find it supportive of very long and relaxing listening sessions? I need a system, where I can get into a meditative, absorbed state without being overstimulated. My main system is with dCS + AIC-10 + Stealth and it does that beautifully.
For the desktop I would be using my Utopia or my VC. Have you used the VC with the HA6a?
It is supportive of any sound you want in this config depending on the tubes you roll in. From totally cosy and full to technical with full detail.
For cosy sound you can try Mullard for technical Telefunken. SE KT88 is also great slightly on the warm side but very detailed.
