Cayin HA-3A, a Compact 6V6s Transformer-coupled Tube Amplifier
Dec 5, 2022 at 9:06 AM Post #556 of 2,531
Not so hasty young padawan.
At this point I would not dismiss the possibility of some alien interventions.
The truth is out there!
Keep digging.
P.S. Seriously hope you get your noise issues sorted out. One thing is for sure, with Andy you are in the best hands here.
Dec 5, 2022 at 10:20 AM Post #557 of 2,531
This is another tube interference myth that I can't think of any solution out of my head. If this is a "human antenna" situation, theoretically when you stand up, the antenna effect should be enhanced and you'll hear more interference.
Let's start the debugging process by checking out your system. Can you describe your audio system in more detail? From the source (a desktop PC?) to the HA3A amplifier including all the interconnect in between. In addition, it is very likely that your interference problem is caused by multiple events, so if you find something that reduced the scale or frequency of interference, you should keep that in place during subsequent tests.
  1. You have tried multiple headphone cables, do you happen to have a 6.35mm headphone cable that has a copper-shielded layer covering the conductor?
  2. As per your photo, you have removed the protector cage, can you try to put the protective cage back on and check whether this will reduce the amount of interference noise? If this does help, maybe you can test with a stronger shield by wrapping aluminum foil around the protective cage to further test.
  3. On top of standing up, have you tried sitting on the chair but moving the chair away from the HA3A? Allowing more distance from the amplifier to your headphone
  4. Similarly, remain sitting on the chair but find someone to stand beside you, at the position where have indicated in your first photo.
Thank you for responding Andy. I will be out of town travelling until Wednesday and then I will be able to roll up my sleeves and work on it again. I look forward to getting this solved !
Dec 6, 2022 at 10:43 AM Post #559 of 2,531
To Andy and the Group - while I am still traveling I came across this EMF detection device. Might this be of use or help in identifying the source of my interference issue? If so I will pick one up.
Has anybody used anything like this ?
Thanks community !
Dec 6, 2022 at 10:46 AM Post #560 of 2,531
Thanks community !
I had that one and it was the best of all I used, it helped me detect that grounding of my building was not working. It has lots of options and you can make graphs and database if you let it work 24h, very useful device
Dec 6, 2022 at 10:53 AM Post #561 of 2,531
Thanks community !
I also thought I might try some of this EMF cloth to see what affects the interference:
Dec 7, 2022 at 6:36 AM Post #563 of 2,531
I had a chance to do some testing tonight with the aluminum foil. Below are the results. All feedback is sincerely appreciated. I do not want to return this amp, but this solution is truly unattractive :frowning2:
Does the fluttering happen in both channels?
Dec 7, 2022 at 8:32 AM Post #564 of 2,531
Hello guys!
Has anyone compared the HA-3A to a Crack w/speedball with high impedance headphones?
Regardless of price, I'd like to know how they compare.
Dec 7, 2022 at 9:00 AM Post #565 of 2,531
Hello guys!
No idea but I can tell you that HA-6A and HA-3A sounds kind of close with HA-3A having slightly less body to the music and little bit less bass (with default JJ valves), impressive.
Dec 8, 2022 at 11:36 AM Post #566 of 2,531
Is Wi-Fi turned on on the R26? I know you said you are using LAN but I found Wi-Fi was really picked up by the HA-3A.
Dec 9, 2022 at 9:12 AM Post #568 of 2,531
Just received the Tungsram E80CC
Soundstage: Slightly smaller than Tungsram 12au7, wider, about same depth
SQ: More detailed than 12au7 and more lifelike sounding but still tube magic, no strident or digital glares or nothing that could ruin listening experience
Bass is very tight not bloated and not dry at all. Midrange is not forward but female vocals has some magic to it, they sound special. Treble is tamed and detailed, very enjoyable
I had to adjust pot from 9 to 8, E80CC requires more current than 12AU7/ECC82
For me Tungsram 12au7 is soundstage king so far but at the moment I prefer e80cc variant, I bought a pair in eBay from Ukraine seller, total was like 50€
Dec 9, 2022 at 9:17 AM Post #569 of 2,531
:thumbsup: :o2smile:
Which 6V6 you are currently using?
