ThanatosVI
That is correct.Am I right in thinking the Electro Harmonix tubes are Russian?
Yes.Am I right in thinking the Electro Harmonix tubes are Russian?
Stay updated on Cayin at their sponsor profile on Head-Fi.
Looks like a very warm combination. All sockets are filled with a warm tubeHappy 2023!
I'm finally all NOS in my amp. And RCA too - they are the easiest to find lol.
RCA 22DE4 (just NOS)
RCA 6V6GT (Gray Glass)
RCA 12au7 (5814a Black Plate)
Also, found tube dampers to help with microphonics from my keyboard that would be heard through the tubes.
Having trouble finding Mullards / Brimars. Hoping for a truly rich midrange, rather than just softer treble. The RCA black plates are smoother than my RCA clear tops and Valvo's, but not as much as I expected. Maybe needs more burn in. I was surprised how smooth the clear tops became after a while. Still very detailed, but not harsh anymore.
I really want to grab some ZMFs again. I'm holding out for an Atrium closed back or a cheaper Caldera-like model. They're too beautiful not to own.The Atrium was the closest to my preferences but also similar to the HE1Kv2. I preferred the HE1Kv2 in the end, but a closed back with a similar sound profile would be perfect!Looks like a very warm combination. All sockets are filled with a warm tube
To give the RCA black plate 5814 more chance to shine through, I use more neutral Mazda 6v6gt and a Sylvania 22de4 rectifier. Very nice euphonic combination for my ZMF Atrium.
I am using this amp with my meze elite chameleons through the xlr output and am really enjoying it. No noise or hiss either. Have been meaning to try out the 4.4mm output, as I have heard similar things that you have, but the xlr output has been so great I haven't had any desire to.I am really interested in buying this amp, but after reading the thread I have a couple of questions.
Some members mentioned that they do not like the XLR out and prefer the SE or 4.4mm out. This especially seem to be true if they are using XLR inputs as well. SE input or SE/4.4mm out seem to be more favourable, but apparently mostly with higher impedance dynamic driver headphones.
I am planning to use the amp mostly with my Meze Elite, which seems to be a favourable combination with the 3A. I use the XLR out of my Musician Pegasus R2R DAC (with SR Purple fuse) as I prefer balanced out of the DAC. R2R DACs also seem to be favourable with the Cayin, but I am wondering if this XLR 'harshness' (can't remember what exact term was used) that some members reported are limited to delta/sigma DACs or simply a too high DAC output level on the DAC's XLR out?
Perhaps some members who don't like XLR out on the 3A could elaborate why exactly they do not like it and also if they use XLR input as well?
Another question is regarding the noise some members reported. Is it mostly a hiss noise what you can hear on certain amps when you turn up the volume without playing music or is it referring to a less black background when music playing compared to some SS amps?
I'm using mine w/ SE & 4.4 mainly because the power lines in my house are not very clean even w/ power conditioners (ifi power stations). What I had to learn the hard way (as the 3A was my 1st Tube amp) is that your environment plays a factor on how well your performance will be w/ this amp and generally tube amps as a whole. It's very much possible you could get the 3A and have no issues at all and have a black bkg but the opposite is also a possibility. The only way to know is to try it.I am really interested in buying this amp, but after reading the thread I have a couple of questions.
Thanks, your comment puts my mind at ease. When it comes to dislikes, there is usually a loud minority and a happy/content majority. If Zach from ZMF is happy with the XLR out from the 3A, I guess I should be too. Sure, there are many variables to take into account, all system chains and usage scenarios are different. But thanks to your comment I think I can eliminate that high level XLR input to the 3A would be an issue as your Matrix has 4.8 Vrms on its XLR out while my Pegasus 'only' has 3.55 Vrms. So, that shouldn't be an issue.I am using this amp with my meze elite chameleons through the xlr output and am really enjoying it. No noise or hiss either. Have been meaning to try out the 4.4mm output, as I have heard similar things that you have, but the xlr output has been so great I haven't had any desire to.
This is all being fed through a Matrix Audio X-sabre3 dac acting as a roon endpoint and connected to the cayin via balanced xlr.
It is true, that ultimately you have to try new equipment in your own home to see how it behaves and how you like it. I am aware of that, just trying to collect as much information as possible before I pull the trigger.I'm using mine w/ SE & 4.4 mainly because the power lines in my house are not very clean even w/ power conditioners (ifi power stations). What I had to learn the hard way (as the 3A was my 1st Tube amp) is that your environment plays a factor on how well your performance will be w/ this amp and generally tube amps as a whole. It's very much possible you could get the 3A and have no issues at all and have a black bkg but the opposite is also a possibility. The only way to know is to try it.
While I do have noise issues as mentioned; using the SE & 4.4 have greatly reduced that issue which has allowed me to enjoy this great sounding amp but sadly I don't have a black bkg as others have been able to experience. Eventually I may invest in a Decware power conditioner to see if that will elevate the noise but atm I'm content.
I totally understand the concept of "collect as much info as you can" I think that most of us have that mind set. I was merely trying to point out that while you can collect many hours, days, weeks, or even months of info as that was my approach (i spent nearly over a year researching tube amps) the end point is you really just have to try a tube amp in your environment to know for sure if its going to fit to your liking. There's no shame in doing research just keep in mind the time spent doing that research. Time is money to put it simply which is why I said you kinda just have to try it to know for sure.It is true, that ultimately you have to try new equipment in your own home to see how it behaves and how you like it. I am aware of that, just trying to collect as much information as possible before I pull the trigger.
On another note, why are tube amps so much more sensitive than SS amps? The 3A would be my first proper tube amp too, I had several SS amps before and a couple of hybrids.
Cheers mate, I have just edited my previous post which basically echoes your advice. I will report back for sure once my first proper tube amp arrives.I totally understand the concept of "collect as much info as you can" I think that most of us have that mind set. I was merely trying to point out that while you can collect many hours, days, weeks, or even months of info as that was my approach (i spent nearly over a year researching tube amps) the end point is you really just have to try a tube amp in your environment to know for sure if its going to fit to your liking. There's no shame in doing research just keep in mind the time spent doing that research. Time is money to put it simply which is why I said you kinda just have to try it to know for sure.
Anways I hope you get what your looking for, gluck.
You'll have plenty of fun The Elites sound terrific on a tube amp!Cheers mate, I have just edited my previous post which basically echoes your advice. I will report back for sure once my first proper tube amp arrives.
Edit: trigger pulled, the 3A should arrive early next week. Will see how it stacks up to my expectations. The GSX-Mini has been my favourite SS amp so far, beating the Soloist 3XP, iFi iCan and many others. Yet after tasting R2R with my DACs I am craving for something even more organic which I hope tubes will offer.
