- Oct 14, 2013
From this official specification. Seems feasible that Building a dedicated Linear regulated Power supply and modify the C9 to have the ability to take the LPSU will solve it power supply issues.
- You can charge and playback C9 at the same time before the batteries is fully charged. 18650 Lithium battery charge control is divided into two phases. The first phase is constant current charging. When the battery voltage is lower than 4.2 V, the charger will charge with a constant current. The second stage is the constant voltage charging stage, when the battery voltage reaches 4.2 V, due to the characteristics of the lithium battery, if the voltage is high, it will be damaged, the charger will fix the voltage at 4.2 V, and the charging current will gradually decrease. Therefore, if you charge and playback at the same time and your charging rate is faster than discharge rate, the 18650 batteries will reach 4.2V eventually. The problem is, when you continue to charge and playback at this moment, C9 power management cannot enter the constant voltage charge stage, this will put C9 into protection mode. You can revoke C9 from protection mode by disconnecting everything and charge it for 10 second. You are advised to disconnect C9 from charging when the fourth battery LED is flashing in these circumstances
Dual rails with ground split will allow it to have a dedicated dual rails of LPSU
However, battery is clean and have it own advantages
- Do not charge and playback both C9 and the connected source (let’s assume that is a DAP) at the same time. The four pieces of 18650 batteries are connected as a +8.4V and -8.4V power supply for the amplification circuit, and there is a set of ground line in between and that is connected to the C9 chassis. The charging circuit via USB-C has its own reference Ground connected to the USB socket. Be reminded that these two Ground are completely independent. If C9 and the DAP are charge and play at the same time, the power supply Ground (C9 Chassis) and charging Ground (USB socket) will short circuit by the charging cable and interconnect between C9 and DAP. C9 will enter protected mode. You can revoke C9 from protection mode by disconnecting everything and charge it for 10 second
