Creatures of the night including me
Enjoying some music
And I hope you as well ...
Enjoying some music
I was scolded here for using an adapter like that to feed my C9. Actually though, I found that just using the SE line out from SP2k is really good with C9.The Cayin C9 charge circuit will automatically adapt to the wattage it requires will it not?
I'm contemplating unplugging the 100W USB-C MacBook charger from my MacBook and charging the Cayin but not sure I should... (yes it works just fine but I made sure I switched it off well before it was at full charge just to be safe)
The Cayin C9 is up there with the very best portable headphone/IEM amplifiers I have ever heard. I very much enjoy it with the SP2000 -> C9 -> Oriolus Trailii combination.
I use it to power my Diana V2’s when travelingI want to understand something, I see a lot of people here use c9 with iem, and I wonder if this is what c9 is for?
It's an amplifier with a lot of power, for me it easily moves the hd800, and iem's not need a lot of power and dap is definitely good enough for them,
Another question, about what volume do you put your dap on when you connect it to c9?
Thank you!
I use my C9 for IEM’s and full sized headphones. It works great powering both.I want to understand something, I see a lot of people here use c9 with iem, and I wonder if this is what c9 is for?
Thank you!
When you connect from dedicated line out mode, C9 controls volume. In Pre-Amp mode, your DAP controls volume, so pls start with volume turned down on your DAP and then adjust to a comfortable volume. Otherwise if you have turned up volume too high on your DAP, when sound kicks in you may suddenly damage your hearing.I want to understand something, I see a lot of people here use c9 with iem, and I wonder if this is what c9 is for?
Thank you!
I bought the C9 for my Hugo2+EE Odin under the impression that this is an IEM amp that has the potential to drive full size cans. After I got it, I found out that I can’t use the 3v LO mode on Hugo2 since it’s too hot and I can’t turn the volume on C9 past 9 o’clock for the Odin. My only other IEM is a Solaris SE which is more sensitive so I didn’t even try that on LO. At the end, for my IEM listing, I just fix C9’s volume at 12 o’clock and using Hugo2’s volume ball to adjust, which it could barely pass 20%(red).I want to understand something, I see a lot of people here use c9 with iem, and I wonder if this is what c9 is for?
Thank you!
This is an interesting phenomenon- certainly on LO from R8 I am experiencing no volume problems of this nature. At one point, I connected IFI micro iDSD to C9 via single ended RCA LO and found that on Turbo mode I was experiencing clipping but when I turned Turbo off and decreased IEmatch to ‘high sensitivity’ it all resolved. Could this be a gain issue on the Hugo2 side?I bought the C9 for my Hugo2+EE Odin under the impression that this is an IEM amp that has the potential to drive full size cans. After I got it, I found out that I can’t use the 3v LO mode on Hugo2 since it’s too hot and I can’t turn the volume on C9 past 9 o’clock for the Odin. My only other IEM is a Solaris SE which is more sensitive so I didn’t even try that on LO. At the end, for my IEM listing, I just fix C9’s volume at 12 o’clock and using Hugo2’s volume ball to adjust, which it could barely pass 20%(red).
IMHO, adding this amp improve the Odin somewhat, mainly the soundstage and placement but not much else over the Hugo2. Surprisingly, it made a big improvement on the Solaris SE, made everything better all around. I think I read somewhere that the C9 has the ability to make mid tier IEM sing like a TOTL. Maybe this is the effect people are talking about?
It’s a much more straightforward story on my headphones. Hugo2’s LO or C9’s Pre mode all work beautifully and even has slightly different flavor in sound to my ear. It made my LCD4z more lively, spacious with better bass. A meatier sound overall. It can even drive the Diana TC to an enjoyable level. Not FULL potential, it’s not that magical, but it definitely can offer some enjoyable listings over a short trip.
Overall, very versatile and capable amp.
