I notice when I charge it, it shouts from 2 lights to four. When in use it, after a few mins it drops from 4 lights to 2. Is this to do with battery conditioning?
When I got mine first it used to stay on 4 lights for hours and then the battery would start to die quickly. I let it run down completely and then fully charged it and the indicators work better now so it may help you too. It was recommended somewhere else in this thread to fix it.
Should be battery problem, if this is your first cycle after you acquired the C9 again, maybe not all 4 batteries are in full charge, so the overall voltage drop quickly once they reach certain point. Discharge and recharge normally can rectify the problem.
Good move. I've had my since it came out and continue to love it, especially via N6ii/A02. I can't really think of anything that didn't sound fantastic on it.
Been listening to DT1990 Pro via TT2 & C9 this morning - another great sounding set-up.
The TT2 should be more than capable to handle DT1990 pro, wonder what mode did you use in C9? I assume you want to add a warmer presentation to your DT1990 Pro?
Exactly. Not a question of power but a question of colour. I find the C9 slightly "tames" the peaks on the DT1990 without in any sense augmenting the technical presentation. Generally I use the TT2 on its own, but it's nice to have the option for a different tonality.
I didn't. This is actually the 4th time I've owned the 1990Pro and i generally use Dekoni velour elite pads for any peakiness but I find it's not necessary with the C9. It's a fantastic pairing.
I just discharged it completely and then started to charge it again. It seems to charge properly for the first two lights and then just jumps straight to 4th light. I’ve taken the batteries out and puts them back in. Same result
+1. I would also like to hear about any impressions of the final A8000 with the C9, mainly for a bit of coloring. More, I would like to hear about the A8000 on the N6ii, any module(s) you have. Thanks!
The C9 is just amazing with everything I have tested so far.
Tonight I am greatly enjoying it with the Focal Clear MG pro.
Very holographic and dynamic.
Till with all my headphones I haven't reached for the high gain.
I just got my C9 and can't get it to turn on. I put it to charge and the 4 LEDs turn orange but the device does not turn on even with the battery at maximum ...
Did you open up the unit to charge the batteries? If so, you need to plug it in again once you close the C9. Then, it will turn on. This is a safety feature.
Yes, I just got a Susvara after having owned the C9 all year. Andy Kong said it wouldn't drive it properly and I can confirm that the sound is very bad. It sounds very compressed. I only have the gain set to about 2 pm, but it really sounds bad.
