Set your controls for the heart of the sun.I got that one wrong, it was a hookah-smoking caterpillar. Had to go listen to Grace sing it. See what y'all are doing? sending me into flashback mode.
Cayin C9: Dual Nutube, Fully Balanced Class A/AB Portable HeadAmp
- Thread starter Andykong
Shawnb
- Dec 2, 2012
One pill makes you larger
And one pill makes you small,
And the ones that mother gives you
Don't do anything at all.
Go ask Alice
When she's ten feet tall.
And if you go chasing rabbits
And you know you're going to fall,
Tell 'em a hookah smoking caterpillar
Has given you the call.
Call Alice
When she was just small.
When the men on the chessboard
Get up and tell you where to go
And you've just had some kind of mushroom
And your mind is moving low.
Go ask Alice
I think she'll know.
When logic and proportion
Have fallen sloppy dead,
And the White Knight is talking backwards
And the Red Queen's "off with her head!"
Remember what the dormouse said:
"Feed your head. Feed your head. Feed your head"
Does anyone wright lyrics like this anymore?One pill makes you larger
Go ask Alice
Call Alice
Go ask Alice
DaYooper
Just the ones who made it to the bottom of the rabbit hole.Does anyone wright lyrics like this anymore?
Are there any negatives if I was to use a 3.5mm SE headphone cable converted to a 4.4mm Balanced via an adaptor or adaptor lead in to the C9?
bluestorm1992
As I understand it, you should NEVER convert a SE cable to a balanced one. It will short the player/amp and damage it.Are there any negatives if I was to use a 3.5mm SE headphone cable converted to a 4.4mm Balanced via an adaptor or adaptor lead in to the C9?
Interesting.... As there are many converters on the market. Glad I checked to make sure. Thanks bluestorm1992.
This is one of the top DO NOT DO THIS recommendations on Head fi. You can go from a balanced cable to a single end output, but not vice-versa due to the ground loop issue. You will end up putting your amps at risk of shorting out. I've never tried it for this warning, but it makes sense.Are there any negatives if I was to use a 3.5mm SE headphone cable converted to a 4.4mm Balanced via an adaptor or adaptor lead in to the C9?
bluestorm1992
Sure. You can always safely convert a balanced cable to a SE one. I believe there are most of the adapters for.Interesting.... As there are many converters on the market. Glad I checked to make sure. Thanks bluestorm1992.
If you want to use a balanced source, get a balanced cable. Most balanced terminations are different connector sizes so you can't make a mistake on accident. But, there is a 3.5mm SE and 3.5mm balanced. Using that connector incorrectly is where you are going to potentially go awry. As a result, I never buy anything with 3.5mm balanced. I either have 3.5mm or 6.3mm single end or 4-pin XLR, 2.5mm and 4.4mm balanced. And, I have adapters to go from 4-pin XLR to 6.3mm, 3.5mm single end, 2.5mm and 4.4mm balanced. Also, I have adapters to go from 2.5mm => 3.5mm single end or 4.4mm balanced.Interesting.... As there are many converters on the market. Glad I checked to make sure. Thanks bluestorm1992.
To stay out of trouble, only terminate unbalanced cables to 6.3mm or 3.5mm single end. Balanced cables can be used for any termination with the correct adapter and they are plentiful.
No probs.... I've just changed my IEM & cable order from 3.5mm SE to 2.5mm Balanced. Then ordered a 2.5mm to 4.4mm Balanced adaptor. Thanks to all!
- Oct 14, 2013
It is interesting that the Battery modules has a dual rails mirror feedbacks regulator inside itself, and that the C9 will not turn on if it can not see the Battery modules.
So at the moment, there is potentials to modify the battery modules to take in possibly larger battery cells at the same nominal voltage as 18650 in it own housing by using the module and let it regulate the rails as needed.
External power supply may not be possible due to the way this is setup
Shame they only had a 2.5mm Balanced option available on this particular IEM kit. But at least my C9 &/or IEM won't fry!
When A&K gives up on 2.5 maybe it will start to become even more uncommon. 3.5SE is real common to. 4.4 balanced for IEMs seems like it is really gaining traction, my preference for portable.Shame they only had a 2.5mm Balanced option available on this particular IEM kit. But at least my C9 &/or IEM won't fry!
Yes. I agree. I did think it was pretty weird only offering this size (other than the 3.5mm SE). I also bought another IEM cable from the same retailer terminated with a 4.4mm Balanced plug as an upgrade to the one supplied... now 2.5mm Balanced... cable.When A&K gives up on 2.5 maybe it will start to become even more uncommon. 3.5SE is real common to. 4.4 balanced for IEMs seems like it is really gaining traction, my preference for portable.
