- Oct 6, 2013
Anyone paired C9 with LPGT ?
would be interested in outcome
thanks
I covered that in DAP pair up section of my write up, please scroll down my review.
thanks
Whew, I'm off the hook now.I covered that in DAP pair up section of my write up, please scroll down my review.
Hi Andy,
Just to confirm, I'm talking about using the XLR pre-amp outputs on the rear of the A90, not the headphone outputs in the front. My understanding is the XLR pre-amp output is the same as the headphone out, but with an extra 40 ohm resistor. Would this still not be suitable to use with C9 in Pre mode? Thank you.
Stay updated on Cayin at their sponsor profile on Head-Fi.
Just turn off before unplugging and that is that.Don’t know what that means, but it sounds dangerous. Maybe there is something to equipment getting damaged when used with the C9?
Andy perhaps that should be added to the instructions as a caution. I remember reading these kind of cautions when changing lenses on my Nikon camera, to switch the camera off before changing lenses.Just turn off before unplugging and that is that.
I have a Hiby R6 2020. What do you think the pairing would be like for that DAP with the C9 vs the R8? Would it be similar?I covered that in DAP pair up section of my write up, please scroll down my review.
Looks like I’ll be snagging this with the C9 when musicteck has it all available.
Does this also mean the amp can damage the source?Please allow me to share some thing I just collectively found.
We have all found that the 4.4mm input on the C9 is connected toward ground in the sleeve.
By design, when unplugging, the R- toward the ground will be momentarily shorted before the detector can disconnect the circuitry. This momentarily short during the amplifier being live is no good.
So I recommend to turn the C9 off before any unplugging
The same thing as the A02, make sure you turn off “auto plug and play”. Then turn off the playing app before you “unplug”
No amp can damage the source, a bad cables will and it had happened before.Does this also mean the amp can damage the source?
Doubt it!!! Look good though, and if you are running Class AB with Solid State constantly, then this will be a good buy as the Amp does not heat up as much. The vents ok the sides, too, bottom are likely enough to dissipate heat under this circumstancesI’m just concerned about if this will dissipate the heat effectively...
