Maxvla
- Dec 26, 2002
Yes, grats Chris!
[size=11pt]As you are aware, Cavalli Audio is gearing up the new Spring production run. Despite a small setback, we are moving forward with a new partnership and on schedule to deliver LL and LAu this Spring. One of the most highly anticipated releases is revision II of the Liquid Fire. Despite our best efforts, that production run took the largest hit, and will not be able to be restarted. I would rather ensure utmost quality for the products delivered, than spread things to thin and not be able to give the Liquid Fire the attention it, and you, deserve. [/size]
[size=11pt]In lieu of this, we've decided to make a special offer to the community and offer the Liquid Glass at $3,500, a discount from $3,750. This price will be effective for the all the remaining LG amps. While this is a little more than the original Liquid Fire, the LF MKII would have had a small price increase with the additions that were in store. [/size]
[size=11pt]Many listeners who have heard both the Liquid Fire and Liquid Glass had a preference the Liquid Glass. I like them both, but I can understand this conclusion. The original Stacker amps are still part of headphone amp mythology. [/size][size=11pt] Not to mention, many original LF owners spent a lot of time tube rolling even though the LF was not really designed for it. The Liquid Glass, OTOH, let’s you roll tubes as much or as little as you want! [/size]
[size=11pt]So, if you wanted a Liquid Fire 2, the Liquid Glass is available at a great price as a special offer to our fans. [/size]
[size=11pt]For this Spring, the Liquid Lightning 2, and the Liquid Gold are already beginning production, and pre-order information will be coming shortly. Thanks for your patience. Stay tuned, more to come![/size]
Balanced I see...
If you're referring to the LF or LG it's a SE 4 Pin out.
SE 4 pin out? A 4 pin XLR out is used for balanced (or 2 x 3 pin XLR) wouldn't it be easier for Cavali to just use a single 6.3mm chassis mount jack for SE?
People requested a 4 pin out because they have headphones terminated for that from different amps. It works the same way the EF-6 does. It's for convenience.
