Shane D
I wear mine at the gym, the clamp is fine! I’ve had them over a year, so unless they changed the headband your good
You must get them really sweaty? I will try that clamp tomorrow.
That will be tight!My first shot:
I found this very helpful to get it comfortableMy first shot:
Lol, good luck you might have to re-adjust a bit for the first couple days but if should stay put. If you don’t like it it’s pretty easy to unbend themI was watching the video while squeezing feverishly.
VERY curious to see how it works tomorrow.
Yikes! I don't think I could ever do that to the headband of my Cascade...My first shot:
I had a few comfort issues the first month or so, but since then either I've got used to it, or the headband has stretched enough I don't really notice it any more.
Different heads, different bands.. or something like that?I need less pain and more clamp. It is a step in the right direction.
The XL pads are definitely larger! Makes the cascade feel more like a full size headphone than a portable one if that makes any sense.How do the XL pads go?
The small pads out me off but see they have XL now. So interested again!
Can you provide any physical dimensions for the inner cups of the XL pads and the stock pads, by any chance?The XL pads are definitely larger! Makes the cascade feel more like a full size headphone than a portable one if that makes any sense.
Just measuredCan you provide any physical dimensions for the inner cups of the XL pads and the stock pads, by any chance?
the Audeze pads for reference are
1.75”x25”x1”
