Regarding DSPs, I wasn't referring to the computing power, I was referring to the mathematical calculations being required and timings, an engineer has had to code software for these calculations based on the settings made via your head unit, taking many different settings into account at the same time, (EQ, time alignment, db levels, sub out, channel balance, main volume, crossover, roll off, active crossovers possibly other settings I can't remember), all acting upon a stream of numbers coming in (digital audio), doing mathematical operations to them before passing the modified numbers and timings to the DAC. If any of these calculations are not bang on or have rounding errors on the settings or in the calculations or you have clock jitter then a critical listener such as myself will pick up on it, your average listener wont.
I'm sure there's good DSPs with excellent characteristics and accuracy and there's cheap DSPs as per any electronic equipment and products, it's a gamble and an expensive one when you're looking at a $500 DSP.
So - DSPs / time alignment / RTA for multi amps / multi channel, multi speakers positioned all over your car, separate mid speakers and tweeters - yes I get it 100%, basic but not necessarily low sound quality 2 speakers and a sub, nah.
Anyhow as I've said, regardless of how the time alignment is set I can hear minor distortions in the audio, so that isn't due to hearing 1 speaker over the other problem, but fair enough I'll try time alignment yet again on my 80 PRS and see if I feel there's any benefit to it. I don't see the need for a RTA or pro sound installer to dial my sound in, I have two full range front speakers (no separate tweeters) and 1 sub, there isn't much to dial in.
Overall I just don't get your argument really, you seem to be saying compressed bluetooth is ok, don't worry about it, I mean how do you feel about playing mp3's via your car audio ? personally no thanks, they sound horrid, even mp3's with higher bit rates, e.g. the difference in audio quality between Spotify and Tidal is seriously night and day, you'd have to be partially deaf not to hear a difference.
So that's what I'm after, the full Tidal experience and not a compressed experience, I don't see what's wrong with wanting that, taking compression out of the audio chain surely is a sensible thing to do if you're looking for better SQ ??? and yes a better amp and speakers applies to all audio systems.
What you all seem to be saying is play any old junk mp3's and as long as you have a DSP and time alignment they'll sound absolutely great, for me audio has moved on 16bit, 44Khz is CD / old, you all should be wanting 24bit / 96Khz uncompressed, all mp3's should just be deleted
As regards an amp if I'm going for a full sized amp install then I think this might be better, this is a class AB whereas the JBL amp is class D, just to drive the 2 front speakers.
https://www.amazon.com/JVC-KS-AX204...=JVC+KS-AX204&qid=1560792889&s=gateway&sr=8-1
Actually the Sony GS4 sounds really good and it's not that expensive, quote "The XM-GS4 4-channel amplifier is engineered to enhance every track – including High-Resolution Audio files, thanks to an ultra-wide frequency range that extends up to 100kHz." - see now someone is talking my language the eye of sauron is now focused on this amp - i want it
