From an honest manufacturer and even giving a sponsor perspective …
I would really appreciate your sincere opinion about this subject.
I doubt you’ll get a response. Sponsors/Advertisers aren’t protected in this subforum against refutation by science (or even just the facts) as they are in all the other subforums on head-fi, so extremely few ever venture here and if they do, it’s virtually always just to give or confirm some technical/engineering fact, not repeat their usual marketing or opinion.
So basically your saying there no difference in sound between different dac chips
For 20 years or more, the differences between DAC chips have been so small they often can’t even be converted into sound. IE. The differences are often below the resolution of speakers/HPs. So obviously, if those differences are not in the sound being reproduced there cannot be any question of them being audible. Some differences may very slightly affect the actual sound reproduced but at levels which are inaudible. In controlled listening tests, no one has been able to reliably identify differences between DAC chips, for more than 20 years or so.
There is again a possible exception. In the last few years it’s become fashionable to provide the user with different filter choices. Most are again inaudible but there are some exceptions.
and we just hearing the differences is how each source change the sound?
It’s obvious if you think about it. DSP processing is of course deliberately designed to be audible. What would be the point of say loudness normalisation that didn’t audibly change the loudness or of a tone control/EQ which didn’t audibly change the tone, etc? However, if you can defeat (switch off/bypass) all those variables, there’s no audible differences between sources either.
The first step of a controlled test, is to change nothing at all, except the device being tested, in this case the DAC. Even then many/most audiophiles believe they can hear differences. This has always been proven to be a false belief, a result of perception error as mentioned, assuming the other steps of a controlled test have been followed, such as volume matching, etc. The exception again though, is some pathological DACs, NOS DACs for example.
I never really considered that since always heard there was a different in sound signature between say a burr chip compared to ESS, AKM or R2R.
And that’s really what’s so shocking about the audiophile world. It’s not that there’s some misinformation, there’s commonly at least some misinformation about most consumer products. What’s shocking about the audiophile world is that misinformation is commonly the ONLY information available. You have to go out of your way, “off the beaten track”, to find the actual facts. Therefore:
Guess going have to read more on this subject since your offering a different view and one I haven’t considered in the past.
That’s the difficulty, where do you go to read more on this subject? There’s tons of science, going back almost a century (and actual DACs have been around since the early 1950’s) but much of the science is behind paywalls and is often difficult to comprehend without specific education in the field. If you try to “read more” using audiophile sources, it’s virtually guaranteed you’ll be misled.
G
