gregorio
- Feb 14, 2008
Again, we do not convert from 24bit to 16bit, where did you get that? Studio mixes and masters are typically 64bit float (or previously 56bit fixed). In the case of converting that to 16bit, noise-shaped dither is applied so that what is truncated is below -120dB.When converting from 24 bit to 16 bit, there may be truncation or omission of low-level bits of information from the digital audio data.
In theory yes but in practice, not in the slightest. The only information below -120dB is noise and distortion. In fact, as almost no recordings have a dynamic range greater than about 60dB, then pretty much everything below -60dB is just noise/distortion, let alone 1,000 times lower level than that! And, noise/distortion below-120dB is nowhere even close to being audible.if any sound information is truncated or missing, it means that the resolution has decreased.
A 16bit conversion is obviously different from a 24bit version, just as a 24bit version is obviously different from the 64bit mix/master because they obviously have a fewer number of bits per sample. However, that makes absolutely no difference to sound quality because the downstream chain, DAC + amp + transducers cannot reproduce the sound of that noise/distortion, as it’s well below the noise floor of that chain.To be sure, the converted 16-bit file is already different from the original 24-bit studio-master file, and this is not something the most demanding audiophile wants for the highest sound quality.
It’s obviously got nothing to do with what I can hear. As what we’re removing (below -120dB) is not even reproducible by the downstream chain, how can anyone hear what’s not even in the sound coming out of their transducers? And even if it were in the sound, it would be well below human audibility anyway.If you can't hear the difference in sound between 16-bit 44.1KHz vs 24-bit 96KHz studio-master recordings, this doesn't mean all humans can't hear the difference in sound either.
Also, humans can’t hear above 20kHz and adults typically lower than 16kHz. So it DOES mean all humans can’t hear the difference!
Do you really believe 1bit is higher resolution than 16bit? Obviously it’s far lower resolution but with noise-shaped dither it’s perceptually about the same.And don't forget to mention, DSD still has a higher resolution than CD
G
