kingkikapu
Ok the silicone tips are driving me batty. Which comply’s are the go-to tips for Vega? Them vs campfire foam tips?
Thanks for making me not hound it down.
I use medium Comply T400's. They are by far the most comfortable tip I've tried (stock foam, spiral dots, spinfits, and stock silicon being the others). To my ears, the comply tips also lessen the v-shape of the vega to a degree and make them slightly more neutral, taming the upper bass and the treble. There's is still a lot of subbass with the comply though. Silicon tips on the vega make them very bright and treble-y, accentuing the treble and reducing the bass including sub-bass.
What about the silicone tips are driving you batty? I'm just curious.Ok the silicone tips are driving me batty. Which comply’s are the go-to tips for Vega? Them vs campfire foam tips?
I can’t get a stable fit with them. They tend to slip ouout or go too deep and create a suction seal that naturally displaces the driver from its resting position which robs it of proper travel. The result is it absolutely robs the brilliance of Vega to the point that I threw in my iPhone buds and they sounded betterWhat about the silicone tips are driving you batty? I'm just curious.
I know what you mean. I started venting my silicone tips, in order to solve the suction problem. Slippage is definitely an issue. So, I swap out my tips every couple of days. Still... slippage is an issue.I can’t get a stable fit with them. They tend to slip ouout or go too deep and create a suction seal that naturally displaces the driver from its resting position which robs it of proper travel. The result is it absolutely robs the brilliance of Vega to the point that I threw in my iPhone buds and they sounded better
It was especially bad when doing anything physical as sweat and heat only help to lower coefficient of static friction and aggravate the problem. Foam tips just stay put and sealed a lot better for me which makes Vega shine for me anyways.
A CFA x LH labs collab - Asteria, same combo as Dorado but with different tuning.
https://www.phileweb.com/review/article/201711/02/2784.html
