davidmolliere
DX200 to Litz balanced cable with Campfire Audio Vegas
I am looking to upgrade my balanced cable for the Vega and I lean towards the Ref8, but how is the Litz? Not too bright with the Vega?
Feed your wife and child first, otherwise it will degrade the sound of the Vega
Fine.... guess I have to I'm surprised the Mojo got such mixed feedback here, usually it's almost universally positive
Mojo is a solid dac, but not nearly the miracle the fanboys on headfi thump it to be.
its a reference point.The Mojo is amazing...until you hear other better gear (at least IMHO).
However, if you don't know what you're missing, then the Mojo is fine.
Cheers
Cheers
Thanks, and fine I'll bite... but so as to keep this on topic, which portable DAC/Amp might you recommend as the best to pair with the Vega?
I would not want it to weaken any or tame of the Vega's strengths. It would need to be no more than $1k, and if it's DAP I'd need streaming ability. No additional stacking though... either a standalone DAC or DAC/Amp or a DAP with streaming (Tidal) (heard great things about the Sony NW-WMsomething but I believe that doesn't stream)
Unfortunately with your criteria I don't have a lot to add. I'm currently driving my Vega's with the Sony NW-WM1Z, which is a wee-bit over $1K (okay, more bits than a wee-bit) and also doesn't stream. To add to the SQ of the Mojo I added the ALO CV5, but your "no additional stacking" requirement whacks that one.
If you can get away without streaming, the Sony NW-WM1A (which I also have) is also very good, and better than the Mojo IMHO, but doesn't stream. And while it's MSRP is above $1K, if you're crafty and patient you can find it for significantly less. Found mine for ~$800, which was a great deal.
Cheers and happy hunting
Try asking in the dx200 thread mate, im sure some vega owners also have that new DAP. That DAP comes in around $900 or something and them guys seem to really live it...Got it, thanks for the help though! I'll stick with the Mojo for now and report back once I get the Vegas
