Campfire Audio - Introducing 2 new models Hello Andromeda and Nova
- Thread starter KB
- Jan 10, 2016
The 2020 will sound similar to the 2019 with improved imaging, more defined bass, more transparent midrange and cleaner treble. From OG Andromeda to Andromeda 2020, the green Andromeda just keeps getting better and it is still priced the same. The Andromeda 2020 is a brilliant refresh on such a legendary IEM.What does the 2020 sound most similar to in that group?
SBranson
Wow.. I've got an Andromeda Gold on the way but this new OG seems so appealing..
- Jan 10, 2016
One thing certain is that both Andromeda SE: Gold & 2020 sound great and ultimately, it depends on individual sound preference.Wow.. I've got an Andromeda Gold on the way but this new OG seems so appealing..
try to get an leonidas 2 for it .. the iem really scales up with this cable and not in a subtle wayWow.. I've got an Andromeda Gold on the way but this new OG seems so appealing..
areek
I find the dx160 pairing to be dark and too thick. I'm considering getting an iematch to increase the output z. Do you find it to be the same?If only I have the DX160 in blue and gold too. That would be a perfect match.
- Jan 10, 2016
I don't think we are talking about the same Andromeda, was referring to the MW10. Which Andromeda are you pairing with your DX160?I find the dx160 pairing to be dark and too thick. I'm considering getting an iematch to increase the output z. Do you find it to be the same?
- Jan 10, 2016
areek
Green andromeda. V2.I don't think we are talking about the same Andromeda, was referring to the MW10. Which Andromeda are you pairing with your DX160?
- Jun 22, 2015
I would go with the Double Helix Clone Silver, it is a resolution beast and let's everything come thru clean. Also, it's lower in cost but it takes awhile to get.try to get an leonidas 2 for it .. the iem really scales up with this cable and not in a subtle way
- Jan 10, 2016
I have not tried it with the DX160 yet.Green andromeda. V2.
cant say for sure , but i guess its the Palladium what make this cable so awesome soundingI would go with the Double Helix Clone Silver, it is a resolution beast and let's everything come thru clean. Also, it's lower in cost but it takes awhile to get.
- Jun 22, 2015
If you go to the Double Helix or Norne Audio websites they both are against any plating or alloys in the cable. The are both recommending OCC copper, silver or fusion for the best signal transmission and then it's the cable construction that then really effected the sound.cant say for sure , but i guess its the Palladium what make this cable so awesome sounding
I have an Effect Audio Eros II+ 8 wire and a DHC Clone Fusion and find the DHC to sound much better overall and has better ergonomics.
i cant say for Double Helix , but i had a few pure silver and pure copper cables..also mix braids etc.. nothing sounded as good as leonidas 2 , but man taste and ears are different if you havent tried it.. try it its worth itIf you go to the Double Helix or Norne Audio websites they both are against any plating or alloys in the cable. The are both recommending OCC copper, silver or fusion for the best signal transmission and then it's the cable construction that then really effected the sound.
Campfire Andromeda V2, V3 & 2020!
Is the V2 taller than the other 2?
