I switched to spiral dots and have been wearing the Andro's for about 6 hours straight with no fatigue like I get from the stock gels. I think due to the shorter insertion is getting a stronger fit in the canal which keeps them from drooping then causing pressure points.
Campfire Audio - Introducing 2 new models Hello Andromeda and Nova
- Thread starter KB
syke
- Mar 1, 2009
The Spiral Dots on the Andro is still best for me. The Symbio Ws are locked away in the ear tips stash ever since I got them.
I see the Drycaddy is out of stock I wanted to order the cloth cascade pads and the drycaddy at the same time to save on shipping costs.Happens to me all the time. That's why I keep them in the DryCaddy every night
Is the drycaddy basically the same thing if I put a scilican gel pack in my pelican case with my Andromedas?
auronthas
- May 19, 2017
I do plan to also use the "older" non extra faceted shells for some special edition IEMs at a later date.
So to answer your question no there is not a modified smoother rounder corner IEM now or in the works.
Thanks
Ken
Is the new Andro S is of non extra faceted shell as mentioned by Ken back in Sept 2016?
yfei
- Jul 1, 2002
SE846 cable (EAC64CLS) which costs about $25 and is well made (assuming you like the fit).
IMHO, it toned down the treble slightly, making the sound more balanced for my tastes.
BTW, I tried the Andromeda’s cable on my SE846 and it brought out more treble (which they tend to need). Too bad the cable is too short for me though.
Thanks, I just tried SE846 cable (EAC64CLS) with Andromeda, you are right! it toned down the tremble, making andro more balanced and enjoyable for long time listening.
Erfan Elahi
https://www.ebay.com/itm/Dry-Caddy-...w=Drycaddy&_from=R40&rt=nc&_trksid=m570.l1313
it’s back on amazon.com for less than $19.
https://www.amazon.com/DryCaddy-Hea...ry+caddy&qid=1534267727&sr=8-1&ref=mp_s_a_1_1
Thanks I am ordering it.it’s back on amazon.com for less than $19.
However It looks like a tight squeeze to put Andromedas in their with the cable every night.
Anyone using this are you unplugging the cable from the IEM to fit in the dry caddy? Or do you not put the lid on and leave the cable hanging out? I don’t want to wear on the connectors by removing the cable every night
syke
- Mar 1, 2009
It fits with the cable albeit a tight one
Erfan Elahi
Detaching the cables felt really hassle to me. I once tired those were so hard to pull out and put back!
It gets easier.
I usually use the pods in a bigger airtight container, I would not suggest to remove the cables every time.Thanks I am ordering it.
emptymt
I know that CA is using a high quality materials for the MMCX connector, but to be save it is better to not detach it too much as I'm pretty sure it will still fail if you do that too many times.
I asked @malvinviriya to measure the Andromeda demo at Zeppelin and Co., as well as my Andromeda S. When we were wrapping up, we ran into a dude with an Andromeda (plus a Double Helix cable and red Telos Audio stickers). The dude swore the Telos Audio stickers made his Andromeda sound better.
Anyway, here we are:
Campfire Audio Andromeda (Zeppelin and Co. demo)
Campfire Audio Andromeda S
Campfire Audio Andromeda (with Double Helix cable and red Telos Audio stickers)
Not sure how to feel about those stickers, really.
The sticker gives it 10HP.
Total: 15 (members: 0, guests: 15)
