- Oct 20, 2016
That's pretty much how they are. In my previous post, I mentioned that sizing is a hit or miss with the symbio. If you managed to get the right fit, great albeit some colouration to the sound. The JVC Spiral tips are your best bet, second would be the Final Es. The Final Es are for narrower bores, but they fit... very securely... I find the Spiral tips are the only ones that I like in terms of fit, that does not change the sound of the Andromedas.
I haven' had a lot of time with the Andromeda's yet but I did test the spiral dots from my fw01's on them and I thought the sound got brighter than the marshmallow tips they came with.
I've found that foam tips (esp. comply, but also the CA marshmallows) kill some of the Andromeda's air. The Andromeda still sounds very good with them, but I personally prefer the Symbio/Spiral dot sound signatures across all OI I've tried.
If you can, you should also try other sources with different OIs to match your preferences best.
I must have gotten it confused with the Sony Hybrid tips which didn't fit the bore. I remember getting the Spiral Dots but they were too small for me. I'll be looking for a set of mediums soon.
Are you listening from your iPhone X? If yes, I could understand why. The highs are harsh from the iPhone (this coming from someone who loves treble).
Add an iEMatch to your lightning adapter if you want the 2.5 ohm out (that’s my personal favorite). Embrace the double dongle life!
I don’t hear hiss with the dongle, so you should be fine on that front.
Yep. That's why I think I like the MM tips the best. Slightly dials back the strong peaks I was getting on the gels.
Does the IEMatch change the signature?
Yep, the sound signature of the Andromeda is sensitive to the output impedance of your source, for which the iEMatch gives you a choice of 1ohm or 2.5ohm. 1 ohm (or below, like the apple lightning dongle) makes the Andro darker; the 2.5ohm out sounds balanced with good bass presence and impact while maintaining the Andromeda’s air up top. YMMV of course, subject to your tastes
Another thing I like about the iEMatch is it makes the Andromeda less responsive to volume changes on my iPhone, giving me finer control over the volume. I’m happy with the combo.
Are you running iPhone X + Andro combo?
I usually use them with my iPhone 6 + iEMatch. Can try them with my iPhone X this weekend and report back.
if anything, andro's sensitivity to everything is what's so great about it, if you do the research and trust your own taste, you can tune its treble and bass ANY way you prefer it to be, it only becomes problematic when you are so unsure of your own ears that you would trust the taste of others more.
i am no fan of iem-match with andros, for 2 main reasons:
1) it affects microdynamics, one of the very special things that andro does well. It's like ordering sushi and having it deep fried.
2) it is not andro that is hissy, it's your source that's noisy. Get the dragonfly red (>1 ohm) or an iphone (>2 ohm)/ipod touch (<1 ohm) instead.
the killing of microdynamics and imho length of dodgy spc cable sonically cancel out the use of an awesomesauce DAP and 8 wire cable anyway.
