blazinblazin
- Nov 19, 2015
I was not satisfied،
I'm looking for the best
Try Effect Audio EROS II+
22AWG Litz copper and Silver cable.
The speed is incredible.
Wish i had the same experience as you >< never got into the qp1r sound. Doesn't the andro hiss a lot from qp1r?Thank you for the advice to buy qp1r•The DAP was one of the best things I bought :thumbsup_tone3:
Ken's new Reference 8 cable is awesome. I have one I use on both my Vega's and K10's. Cheers
I thinking about silver cable![]()
Definitely do a high purity silver cable. The added bass impact will really surprise you.
Stay updated on PlusSound at their sponsor profile on Head-Fi.
It all depends, not every pure silver cable will perform the same, even heavy gauge premium high purity silver. Have here with me TWag v4 and Thor II+, the same gauge pure silver wires, 4 separate conductors, and yet Thor II+ actually adds more rumble to low end, while TWag v4 goes for more analytical/revealing upper mids/treble sparkle.
Ref8 is very good, great balance of low end and top end refinement. Per the question above, Ref8 will have a little more memory effect and slightly more microphonics, while original ALO SPC Litz is softer and "quieter".
I've got several silver cables and nothing compares to Norne Audio's Silvergarde IEM. I believe you and I are listening to the same gear.
