Campfire Audio - Introducing 2 new models Hello Andromeda and Nova
Aug 3, 2016 at 4:16 PM Post #2,536 of 9,829
http://headfonics.com/2016/08/the-andromeda-by-campfire-audio/
That's a great write up, with all those words that I still don't entirely know the meaning of.
Aug 3, 2016 at 11:05 PM Post #2,537 of 9,829
Anyone tried the new Audioquest Dragonfly with the Andromeda? Just wondering if it's a good pairing (not sure which to get, Red or Black version either)
Aug 4, 2016 at 12:52 AM Post #2,539 of 9,829
I just did actually, a few days ago, crazy enjoyable pairing!! Really punchy and authoritative
Which one did you try, the Black or Red? I'm leaning towards the Red since it has a nicer DAC, but I am wondering if it will be too much power/
Aug 4, 2016 at 3:10 AM Post #2,541 of 9,829
  Sounded fine paired with the Nova. I was listening to the Dragonfly Red if it helps at all.
Cool thanks, so no hiss or anything like that?
Aug 4, 2016 at 4:07 AM Post #2,542 of 9,829
I have yet to hear anything that the andromeda doesn't hiss with. Ok there are a small handful of things, it hisses slightly with the dragonflies but it is tolerable.
The black has a punchier, harder edged sound that on first listen sounds cleaner, but with the red, you get noticeably better spatial separation, as well as a smoother, more refined, slightly more laid back sound. The red might seem a tad mushy on first listen compared to the black, but on a longer listen, the red is actually more refined and smoother, the black'a "clean" edge starts to sound a bit more digital, harsh and unrefined vs the red.
That Said both are really great value and sound great.
Aug 4, 2016 at 4:30 AM Post #2,543 of 9,829
Ok, so Red isn't too much power then? How much volume do you end up using with it?
Aug 4, 2016 at 11:46 AM Post #2,544 of 9,829
The andro doesn't hiss with my AK 380cu. Total silence.
Aug 4, 2016 at 1:04 PM Post #2,545 of 9,829
Well 4K is way more than I'm looking to spend though. Can't decide if I should go DAP or add a small DAC/Amp to my iPhone
Aug 4, 2016 at 2:42 PM Post #2,546 of 9,829
I believe ExpatinJapan uses a Centrance HifiSkyn with his Andromeda / iPhone combination as well as the Opus #1 DAP, so he may be a good person to comment on the merits of Dac/Amp vs dedicated DAP?
Aug 4, 2016 at 8:26 PM Post #2,548 of 9,829
depends if u like stack?
Not particularly, trying to do something that will fit in pocket, so either a small 2 piece solution or a DAP that doesn't yet exist seem to be my options.
Aug 4, 2016 at 8:26 PM Post #2,549 of 9,829
I carried an X5 / E12A brick around with me for a while and thought it was fine. Since picking up my Questyle, I can't see the reasoning for "carrying" two pieces of gear anymore. SQ wise, there's not a lot under $2K that'll touch it.
Aug 4, 2016 at 8:58 PM Post #2,550 of 9,829
I used to love my stacks.
No i prefer a one piece such as the hifi skyn (two in one really), or just a dap.
A dongle like the Dragonfly would be ok too(i havent heard the recent versions but the Dragonfly always gets good press).
What phone do you have goldendarko?
