Campfire Audio - Introducing 2 new models Hello Andromeda and Nova
- Thread starter KB
Kunlun
- Jan 25, 2010
I've been using the generic tips that come with the savant. However, monster supertip foams work as well.
goldendarko
- Nov 9, 2013
Didn't really see an answer so which Spinfits fit the andromeda?
Do the standard Noble tips fit the Campfire series? I have a full set that came with some second hand Aurisonics but never thought to try them. Enjoying the extra clarity the Nova seems to exhibit using the CF silicone tips over the comfier foam tips, but finding it difficult to get a good seal. Will have to dig the Nobles out of my tip stash and give them a try!
Midgetguy
I believe I have the CP100 on mine.
goldendarko
- Nov 9, 2013
Thanks, didn't say either one was compatible with Campfire Audio so it was hard to tell which one would fit.
Midgetguy
Yeah, I had some on hand cuz I bought several sets for my Earwerkz Supra. Since the Nova is kinda shallow fit for me, I use the mediums on it whereas I use the XS for my right ear and S for my left ear on my Supra.
- Oct 6, 2013
Cut the wires!!!!!!!!! This new Westone Bluetooth cable works with any mmcx based IEM/CIEM (just quickly tested it with Andromeda, Oriveti, P1, Pristine, and Sirius).
I have tested various BT dongles in the past, but don't recall anything that came that close to matching wired vs wireless performance with the same set of IEMs/CIEMs. Not exact 100% match driving Andromeda from LPG vs driving from Westone BT Cable since there is obvious difference between PAW Gold amp section and DAC built into this wireless cable, but it's seriously close. You do get a bit more hissing, but the whole bandwidth is encoded/decoded accurately without significant losses of the low end and the top end (notorious issue with bt compression when you compare wired vs wireless).
Overall, awesome pair up with Andromeda
- Jan 10, 2016
Overall, awesome pair up with Andromeda![]()
waiting for your sirius review anxiously mate
ngoshawk
Headphoneus SupremusReviewer at Headfonics
- Dec 13, 2015
waiting for your sirius review anxiously mate![]()
Wrong thread, mate...
- Jan 10, 2016
Wrong thread, mate...![]()
no mate haha
im curious on the comparison of sirius vs andromeda
kimD
- Feb 5, 2016
Lol nowadays hybrid vs BAs drivers, really unfair.
- Jan 10, 2016
i will go for whichever sounds better regardless of drivers configuration
kimD
- Feb 5, 2016
i will go for whichever sounds better regardless of drivers configuration![]()
Believe me Andromeda will drive you crazy, if you knew how to setup with right cable and Dap also DAC as well
Fidue not my favor
