Campfire Audio Ara
- Thread starter rantng
- Tags
- alo campfire audio
Had the AG, I prefer Ara. The lows aren’t bad, I just got spoiled by hybrids.The Andro Gold is an U-shaped Ara. You can just buy that
RentedEars
If I could only get the USPS to deliver them I will listen to them! . Ugh, hopefully one more day.That sounds intriguing to say the least! Please enjoy and we look forward to your findings
samsie
- May 16, 2005
I have the Zen DAC v2 too. there was background noise when I plugged the Ara in it . I bought the Topping A90 as head amp instead
Well, I took advantage of Campfire Audio's Black Friday / cyber Monday sale and ordered a set of the ARA's. Cant wait to get them in and give them a listen. I have a set of the Andromeda Gold Titanium from the Multiverse sales and they are awesome! I will be listening with an A&K SR25 as well as an iFi Hip Dac2 for my iPhone and iPad, and an iFi ZenDac2 for my MacBook Pro. Will do a compare / contrast post once I receive the Ara's and have given both of them some listening time!
Dobrescu George
Reviewer: AudiophileHeaven
I promised I wouldn't return from vacation just to post reviews, until new year starts, but I had a one more video finished, so I thought it would be a great way to end the year with a boom!
Rather, this one's about an analytic IEM with tons of detail, one of my favorite presentations for 2021, the Ara IEM from Campfire Audio!!
Loving the comfort too, but you may know this, so I hope the jokes, background music and image quality in the video review will be enjoyable and help with ending 2021 in a neat way~
shimigg
- Mar 28, 2014
Hey all,
Got the ARA just now, I like it very much as it is an in the middle child between the OG Andromeda and the OG Solaris, one thing bothers me, it's the treble sibilance and I am very sensitive to that, wondering if a good copper cable could mitigate that ? if so , what are some good recommendations from AliExpress ?
- Jun 22, 2015
Why go cheap on a cable? Here is a better choice, https://doublehelixcables.com/product/dhc-symbiote-se-premium-occ-pure-copper-litz-iem-cable/Hey all,
Raketen
- Apr 5, 2010
Hey all,
do you find it more troublesome than Andro? presumably the issue would be 5-6khz in this case?
personally would experiment with tips (partiularly for smaller bore sizes and/or different insertion depths)
shimigg
- Mar 28, 2014
thanks, will consider thisWhy go cheap on a cable? Here is a better choice, https://doublehelixcables.com/product/dhc-symbiote-se-premium-occ-pure-copper-litz-iem-cable/
shimigg
- Mar 28, 2014
what tips would you recommend?do you find it more troublesome than Andro? presumably the issue would be 5-6khz in this case?
Currently using Spinfit CP145 L , Works great on the OG Andromeda and yes, I find the Andromeda's sound round with no edges and that's what I like about it
Tchoupitoulas
Hey all,
Some have said that a deeper insertion depth helps with this. See here.
Raketen
- Apr 5, 2010
Personally I also used spinfits (green-might be same model?) with Ara, down a size and longer compared to my normal shallow fit IEM size (usually medium), so that I could get a deeper insertion depth.
Though everyones ears have different shapes and canals, so YMMV obviously.
Narrower bores can also help attenuate upper-mid/treble AFAIK, so the included final audio tips might help too if you haven't tried those already.
shimigg
- Mar 28, 2014
I have a pair of the green ones, normally I use the blue ones, will def try that.Personally I also used spinfits (green-might be same model?) with Ara, down a size and longer compared to my normal shallow fit IEM size (usually medium), so that I could get a deeper insertion depth.
I also have a few Final Tips , let the testing begin
I’ve been using these cables and they have been an excellent upgrade for me. https://www.aliexpress.us/item/2251...tewayAdapt=glo2usa4itemAdapt&_randl_shipto=USWhy go cheap on a cable? Here is a better choice, https://doublehelixcables.com/product/dhc-symbiote-se-premium-occ-pure-copper-litz-iem-cable/
Foam tips can tame the highs while increasing the bass.
