Originally Posted by Lorentz /img/forum/go_quote.gif
"how much it costs to get as close to that ideal cable". Ideal cable here being a thin, wieve shielded stranded copper cable.
I should have added - Quality shielding can be had inexpensively.
Originally Posted by BIG POPPA /img/forum/go_quote.gif
Um, Some of those cables have connectors that are Gold, Silver, Rhodium, Palladium, and what ever else. Are made with pure Silver wire, silver plated copper or sometimes cryo treated.
Eye candy, certainly. Sound influencing? No way.
Originally Posted by Donald North /img/forum/go_quote.gif
From my experiences, if there is a difference to be heard, be it a new amp, dac, etc., it will be most obvious to you when you first introduce the change into a system with which you're intimately familiar.
I think the first event is always the most likely time for the strongest placebo reaction as well. Subsequent samples are more about justifying the initial imagined response.
Inexpensive audio interconnect cables usually use a central wire for the signal and outside braid double duty for ground and shield. Better cables have separate wires for the signal and ground, both contained within a shield that is terminated on one end, usually the downstream end. Many inexpensive braid-only cables are not 100% shield - the braid is not tight weave. For 100% it needs to be very tight and often also includes a foil wrap.
This sounds like the 'poor man's balanced' cable. It isn't effective, and by terminating the shield only on one end, the shield becomes a sort of antenna, exacerbating noise rather than eliminating. Twisting two leads inside a cable is ineffective for unbalanced connections, it is the shield only which provides protection. Both wires need the same signal, opposite polarity in order to make common mode rejection, i.o.w. balancing, work.
Twin opposite polarity signal twisted leads, surrounded by grounded shielding in a balanced system is much more optimal than any unbalanced system for preventing noise, again regardless of how much the cable costs.
For unbalanced connections, a single lead, completely surrounded by the grounded shield is most effective. using foil, as well as a braided supposedly does indeed provide better shielding than either alone. One is good for EMI, and one is better for RF. I believe as long as the braid is fairly consistent, the shielding is effective... Same principle as a Faraday cage - it doesn't need to be solid, only consistent. It only degrades if the cable is bent or twisted so as to move or damage the braiding.
None of these things need be expensive, and as long as noise is not a problem, I.E. a properly shielded cable, none affects the sound.
That's precisely my point; if shielding alone is what you're looking for in an interconnect cable, and everything else being the same, why are you spending more money for something else when there's an exactly similar build by radioshack?
As you say, more expensive cables do indeed have a seperate wires for signal and ground (that said, shouldn't there be both live and neutral signal cable as well as a ground for absolute best?), and it's indeed understandable those cables cost more. But to me, it's a whole another cable, not merely "just a better quality cable". It's a cable with an extra signal path.
This kind of refers to a balanced connection. - Different animal than single conductor coaxial. Shielding methods and 'sound differences' (or lack thereof) are two different things entirely.
Originally Posted by PhilS /img/forum/go_quote.gif
Because the wise folks who run this forum have decided that they don't want every sub-forum on Head-Fi to be inundated with the types of acrimonious discussions that occur when people discuss whether cables make an audible difference. And those discussions don't need to be everywhere to be reasonably available to anyone who has any interest in them.
Fair enough. But if one camp is allowed to cite any and all reasons and beliefs, the other shouldn't be hamstrung. The most contentious topics will always be heated, but no advancement will be made if vital components to the debate are forbidden. Mods just have a little more work to do in keeping hotheads like me from spewing vitriol
Still think you need to save everyone from making their own decisions, and newbies are too stupid to find threads that set forth the pros and cons, huh?
Not at all, but the spread of disinformation or half truths does no one any good.
